how to remove boat numbers from sail? - SailNet Community
 1Likes
post #1 of 12 Old 06-24-2012 Thread Starter
NewportNewbie's Avatar
When I bought this sail recently it had boat numbers on it from the previous boat. I did a quick check and it seemed I could grab a corner pretty easily and it came off cleanly. Now when I am trying to really do it the black from the number comes off leaving a tan goop. (Adhesive). Best way to get rid of these numbers????
S/V Cuajota - 1975 WD Schock Santana 30
NewportNewbie is offline
post #2 of 12 Old 06-24-2012
Re: how to remove boat numbers from sail?
Acetone
Flybyknight is offline
post #3 of 12 Old 06-24-2012 Thread Starter
Sweet. Thanks.
post #4 of 12 Old 06-24-2012
Try peanut butter first. Seriously. Rub it on, leave it a half hour or so, then wipe off. You'll know if it needs more time or if it is not working and you need to step up to serious stuff quickly.
Read this somewhere on the Internet and found it better than goof off and such for most problems.
Tastes better too.
Dfok is offline
post #5 of 12 Old 06-24-2012
Huck
smallboatlover's Avatar
i don't think acetone will be good for your sails might eat through them
16' mistral sailboat, And 27' coronado
smallboatlover is offline
post #6 of 12 Old 06-24-2012
1) My source is North Sails.
2) I've done post grad work in Organic Chemistry. Acetone does not attack polyester or nylon.
Dick
SVAuspicious likes this.
post #7 of 12 Old 06-25-2012
What he said ^^^^
puddinlegs is offline
post #8 of 12 Old 06-25-2012
Huck
just saying what i thought jeez
post #9 of 12 Old 06-25-2012
The most female moderator
Donna_F's Avatar
Dock
Huck, I think his name is Dick (I hope). He wasn't attacking you.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #10 of 12 Old 06-25-2012
RichH's Avatar
The adhesive used for vinyl and insignia-cloth numbers is easily and safely removed from sail material by using - GooGone™. Its the standard way for sailmakers to remove these adhesives.
Acetone, etc. greatly dissolves the adhesives and carries what was once a surface adhesive into the weave of the dacron ... which later discolors deep within the fabric. GooGone™ allows the adhesive to soften slowly and then the adhesive can easily be scraped (mostly) from the surface and with minimal penetration into the fabric weave.
RichH is offline
How do I remove old reg. numbers from my inflatable? daren23 Gear & Maintenance 5 02-22-2008 03:31 PM
sail numbers davideureka Gear & Maintenance 4 09-24-2007 11:36 PM
Sail numbers Stryker72 General Discussion (sailing related) 19 09-14-2007 09:08 AM
Sail Numbers WillS General Discussion (sailing related) 5 01-10-2001 06:24 PM
removing sail numbers sedavis General Discussion (sailing related) 5 12-20-2000 06:03 AM
