When you can't reach the seacock... - SailNet Community
 2Likes
post #1 of 24 Old 06-25-2012 Thread Starter
travlin-easy's Avatar
I have three seacocks in my Morgan 33 O.I. that are hidden in a small compartment in the head, under the sink. It's dark in there, you cannot see a damned thing without a flashlight, and you need the arms of an orangutang in order to reach two of them. Each time I reach in there I usually end up tearing a small chunk of hide from my right arm. Not only does it look ugly, but sometimes it hurts like Hell. I sat down and figured out what I needed to access the valve handles, spent $7 on a length of 1-inch-wide X 1/4-inch thick X 4-foot long piece of aluminum, cut a slot in one end, made a few bends, cleaned up the rough edges, and it works like a charm. Thought I would share it with the good folks on this forum.
For some strange reason the direct image links would not connect, so you'll have to open them one at a time.
https://www.box.com/s/b58d77cbf8f57c7ab428
https://www.box.com/s/27fe2fd640be87914c3a
https://www.box.com/s/bdfb6e896fe33ff76a89
Cheers,
Gary
travlin-easy is offline
post #2 of 24 Old 06-25-2012
Seņor Member
PorFin's Avatar
Re: When you can't reach the seacock...
Looks like a winner, Gary.
PorFin is offline
post #3 of 24 Old 06-26-2012
davidpm's Avatar
Now how about a picture in use?
davidpm is offline
post #4 of 24 Old 06-26-2012
St Anna's Avatar
Well, just from my experience, I would risk the loss of skin in order to get a feel of the seacocks. Using an extension arm can easily break them off and then you'd be in trouble.
I would look at alternate ways to access them, if possible
good luck
St Anna is offline
post #5 of 24 Old 06-26-2012
rugosa's Avatar
Ingenuity, the mother of . . .
Shame on you Morgan, typical factory build - easy in the plant, don't worry about the customer, similar to cars
And regarding what St Anna said - any way you can attach a plexiglass mirror inside the locker (velcro works) to give you the best view possible?
Sail on
rugosa is offline
post #6 of 24 Old 06-26-2012
Senior Cruiser
sea_hunter's Avatar
That's why they invented a chainsaw.
sea_hunter is offline
post #7 of 24 Old 06-26-2012
formerly posting as eryka
wingNwing's Avatar
Ha! I had just made a comment in a HerSailNet thread about women sometimes needing to approach problems differently than men just because of limited upper body or hand strength; your seacock solution seems to be along those same lines. Great minds, and all that...
FWIW, we make a practice to go around the boat once a month, on or near the beginning of the month, and exercise each of the seacocks. Keeps them from freezing up too badly, and also cements in our minds where each of them is. Handy in an emergency.
eherlihy likes this.
Cinderella, CSY 33, Photo by Joe McCary
Regret for the things we did can be tempered by time; it is regret for the things we did not do that is inconsolable. - Sidney J. Harris
Shameless self-promotion - my blog for the Annapolis Capital newspaper:
still has some glitches to be worked out. Until then, I'm posting at:
and
! And a new project:
wingNwing is offline
post #8 of 24 Old 06-26-2012
Chastened
Ajax_MD's Avatar
Good idea Gary, just be gentle. The extra leverage will give you the strength to damage things.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #9 of 24 Old 06-26-2012
Reminds me of one of the little gems on the Pearson32, they came with a Pullman sink. Damned hard to find, won't be in your local West Marine store. From the same RR folks who invented the Pullman bed, for the same reason. The whole sink flips up against the wall to make more room in the head. And of course, that eliminated the access problem since there's no "counter" closed in below it.
Nice little idea, never seen it on any other boat.
hellosailor is offline
post #10 of 24 Old 06-26-2012
Call me Ishmael
blowinstink's Avatar
The handles look nice Gary. Still, I am in the open up the access panel camp. What happens if one of the thru-hulls fails and you need to get at the body of it or jam a tapered plug in the hole? If you don't have enough access to maneuver the normal handle, I can't imagine you have enough for proper emergency access. Anyway, throw that in the hopper.
-M
blowinstink is offline
Switching from close reach to beam reach on 20 knot winds Southcoasting Learning to Sail 24 07-21-2012 07:46 PM
troublesome reach dylanwinter1 General Discussion (sailing related) 0 03-20-2010 12:42 PM
Spinnaker Handling: 180 Turn - beam reach to beam reach? SEMIJim Racing 13 06-15-2009 09:43 AM
close reach = beating? SEMIJim Learning to Sail 50 06-17-2007 09:29 AM
