changing tire on trailer with boat on trailer - Page 2 - SailNet Community
post #11 of 15 Old 06-30-2012
rhr1956's Avatar
Re: changing tire on trailer with boat on trailer
Definately place the jack under the axle, not the trailer frame.
rhr1956 is offline
post #12 of 15 Old 06-30-2012
Much to learn...
Capt-T's Avatar
Send a message via Skype™ to Capt-T
In addition to keeping it simple, it is generally accepted for most applications that wheel lugs go on DRY.. otherwise you run the risk of over-torque. Anti-seize, although not a full blown lubricant is NOT recommended. Your torque wrench settings are assuming metal on metal contact with no lubricant.
Capt-T is offline
post #13 of 15 Old 06-30-2012
Those of you who think jack stands are overcomplicating life, have probably never seen a jack fail or a vehicle fall off a jack. If the ground is a little sandy, or not level, or the load not balanced, or the jack simply defective...a pair of jack stands is damn cheap insurance compared to having a boat fall on you.
And while torque specs are based on "dry/dry" there are compensations for using antiseize. If you've never had a stud snap off, often because some highly trained pro simply had his impact gun set on "max", or been unable to change a tire on the road because the stud was frozen, count yourself lucky. In 25 years of checking my car tires (when I mount the snows) I've found that only one shop actually torqued the wheels properly after removing them for a state inspection. Only one shop in 25 years, and at maybe 10 shops. Including a major service chain and a dealership. And I'm not talking about being off by 10%, they're usually been off by about 100%.
A little cheap insurance is a good thing, but if you'd rather rely on luck, go ahead. Luck is all it takes.
hellosailor is offline
post #14 of 15 Old 06-30-2012 Thread Starter
johnnyandjebus's Avatar
OP here, well that was anti-climatic as I hoped/expected. Two new tires in place, I'll be ordering two more on Monday. I won't bother with the details, with that said I agree a little insurance goes along way. The reason for posting the question in the first place.
Thanks again for the responses.
John
"The more I know about people, the better I like my dog."
-- Mark Twain
"If you canít explain it to a six year old, you donít understand it yourself.Ē
--Albert Einstein
johnnyandjebus is offline
post #15 of 15 Old 07-01-2012
4KSB driver.
SHNOOL's Avatar
yep simple... axle jack on the axle in question, loosen the lug nuts, jack away, change the tire, snug the lugs, lower, tighten the lugs, remove jack.. DONE... there is so MUCH lead in that keel, it's a NON-issue, COG is way lower than it looks.
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is online now
Need help getting boat off trailer g0twind General Discussion (sailing related) 16 09-06-2013 03:02 PM
changing bunk supports with spirit 23 still on trailer Southron Spirit North American Yachts 2 03-31-2012 05:53 PM
Trailer tire winterization? kwaltersmi Gear & Maintenance 4 10-29-2007 10:44 PM
Trailer Boat ilnadi Boat Review and Purchase Forum 6 06-17-2004 03:56 AM
Looking for trailer for 23'' boat decatur General Discussion (sailing related) 4 01-10-2002 06:10 AM
