conversation from sloop to cutter - Page 2 - SailNet Community
 5Likes
post #11 of 13 Old 07-01-2012 Thread Starter
Re: conversation from sloop to cutter
I have a Morris Justine 36. It is more correct to say I am looking for a removable inner forestay. Storm sail and additional sail to optimize a 135 genoa. My mast is set up for this hardware and the landing or loading point is right at a bulkhead, fully tabbed to the hull. Appears to be the right place to carry the load to the hull. A stainless bracket across the bulk head and through the deck seems appropriate. thoughts?
GandTsailer is offline
post #12 of 13 Old 07-01-2012
tdw
Super Fuzzy Moderator
tdw's Avatar
So you are not really looking to convert a sloop into a cutter you are thingking of fitting the optional inner forestay and going as Sloop so rightly albeit perjoratively puts it to a Slutter. Deary me.
Actually were you to be aiming at using your new inner for a working sail in conjuction with your genoa then his disdain might be on the mark but if as I presume you simply want an inner to set a staysail then its not a bad idea. If the boat was designed for it then you just need to get the points checked out to make certain all necessary strengthening is in place. Big yes to John's remark re furler.
One thing, is the setup for a Solent or traditional Inner ? If Solent think carefully. They make tacking a genoa a right royal pain in the arse. Traditional inner (as per John E's boat is a much preferable setup imo.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #13 of 13 Old 07-02-2012
Moving the mast is usually a huge mistake, giving a strong weather helm. The staysail doesnt change the balance of a boat much.
Brent Swain is offline
Cutter rig vs. sloop rig Akacake Boat Review and Purchase Forum 21 03-06-2016 09:48 PM
Sloop vs. Fractional Sloop vs. Cutter Epiphany Boat Review and Purchase Forum 39 01-31-2016 07:12 PM
From Sloop to Cutter kccollbran Gear & Maintenance 10 04-10-2008 12:56 AM
turning a sloop rigged cutter into a cutter (different) aurielthirtyfour General Discussion (sailing related) 5 07-11-2007 09:33 AM
turning a sloop rigged cutter into a cutter (different) aurielthirtyfour General Discussion (sailing related) 3 07-10-2007 07:37 PM
