Tiller conversion to wheel - Page 2 - SailNet Community
 2Likes
post #11 of 13 Old 07-01-2012
Re: Tiller conversion to wheel
IMHO, there's no reason on our little blue marble to have a wheel on a boat less than 35' and even larger if it's a lighter displacement boat. To the OP, please don't waste your time and money on the conversion. Take the cash and buy new sails, get the rig tuned, get a tiller pilot, etc.... Tiller pilots work fine. On our boat you need to balance the sail plan for reaching, but it's not a big deal. For true long distance single or short handed stuff, I'd invest in a wind vane system. Apologies for the strong opinion, but there are just more effective places to spend money on a boat.
CalebD likes this.
puddinlegs is offline
post #12 of 13 Old 07-01-2012
Old Gaffer
FishSticks's Avatar
In defense of a wheel....
Made the conversion in my 33 ft schooner with a $35 Ross steering gear recycled from a truck. It is connected to the top of the rudder post with a simple 3-jaw coupling. This was done about 45 years ago and so far it seems to be working OK. The wheel allows for many different seating or standing options, the best of which is reclining against the lee side lifelines. I gained cockpit space and installed a binnacle in it's proper place.... previously the no man's land occupied by the tiller's sweep.
Ross worm gears are almost maintenance-free. Pack in some grease and that's all there is to it. The full range is about 45 degrees to either side with a total of 6-3/4 turns. The only maintenance required is occasional replacement of the elastomer in the coupling. My rudder post is vertical and the gear is mounted atop the after deck.
Never sail closer to the wind in degrees than your age
FishSticks is offline
post #13 of 13 Old 07-02-2012
Barquito
Barquito's Avatar
I would think that larger boats that have transom-hung rudders would have longer tillers. This would give you more mechanical advantage.
I'm in the same camp as the 'tiller people', however, there are obviously lots of boats out there with wheels, so, the other camp is well represented.
Valiant 32
Barquito is online now
Wheel to tiller conversion possible? utchuckd Gear & Maintenance 20 07-15-2013 03:30 PM
Crealock 37 Wheel to Tiller Conversion MarcHall Pacific Seacraft 11 04-01-2013 07:53 PM
Wheel to Tiller Conversion Skipper Joe Gear & Maintenance 4 11-17-2010 01:13 PM
Wheel to Tiller Conversion DaveMancini Pacific Seacraft 32 10-31-2010 05:12 PM
