Damn boom bouncing all around and sail fluttering. - SailNet Community
post #1 of 13 Old 07-02-2012 Thread Starter
KIVALO's Avatar
Dock
So I went for a sail yesterday and I had the main reefed. On port tack, always and only on port tack, the sail would flutter and the boom would bounce. It did this in all but very light winds and did not change significantly whether close hulled or broad reach or any other port tack. I also tried it with & with out the jib up, same results. I also had no vang installed.
Why did it do this? And why only on port tack?
Thanks,
Brad
s/v KIVALO
s/v KIVALO
2003 Hunter 260
"Any damn fool can navigate the world sober. It takes a really good sailor to do it drunk." - Sir Francis Chichester while loading his boat with gin.
WORK IS OVER-RATED
KIVALO is offline
post #2 of 13 Old 07-02-2012
Re: Damn boom bouncing all around and sail fluttering.
Boom bouncing; install and adjusting the vang tight, adjust the main halyard tighter, and check the main sheet and traveller.
With tight boom vang and tight main halyard the boom should not be free to bounce.
1970 Havsfidra 20 by Fisksatra
On the Delaware River at Fox Grove Marina Essington PA
Ulladh is offline
post #3 of 13 Old 07-02-2012
What kind of reefing? if jiffy/slab, which tack you're on shouldn't matter.
But roller-reefing (boom rolls), could be a difference since sail foot isn't directly over the boom.
Or in-mast furling/reefing? I don't know, except those guys don't have enough battenning to stabilize the leech, which could make your boom want to vibrate.
Other than than, I'm at a loss beyond the tight vang (do you have a vang?) advice given by others. Or if you have a traveler, you could ease it all the way out so the mainsheet is pulling more downwards than sideways.
nolatom is offline
post #4 of 13 Old 07-02-2012 Thread Starter
KIVALO's Avatar
Dock
The boat is a Hunter 260 with factory reefing system, no main roller furling. I thought of the vang issue(I don't have one installed right now) but I discounted it because it only happened on port tack. That's what has me so confused.
Thanks for the responses.
Brad
s/v KIVALO
s/v KIVALO
2003 Hunter 260
WORK IS OVER-RATED
KIVALO is offline
post #5 of 13 Old 07-02-2012
"And why only on port tack?"
Probably some set or drift was making your tacks uneven, even if you thought they were the same. Current offsetting you, wind misread a bit, mast maybe out of column...If you look over the whole picture you'll find something wasn't the same on both tacks.
And of course, a vang exists for a reason.
hellosailor is offline
post #6 of 13 Old 07-02-2012 Thread Starter
KIVALO's Avatar
Dock
Current was non-existent or negligible at best as I am on a small inland lake. I was trying to point higher on port tack but due to the boom bouncing and sail fluttering I tried several other points of sail and all got the same result, unless the wind slowed, then everything was fine.
Confusing!
s/v KIVALO
2003 Hunter 260
WORK IS OVER-RATED
KIVALO is offline
post #7 of 13 Old 07-02-2012
Remember you're a womble
PaulinVictoria's Avatar
Barring the obvious things you could see (like there is a massive lump sticking out one side of the hull), I'd guess that the standing rigging on one side is tighter than on the other.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #8 of 13 Old 07-02-2012
Sounds like the rig is out of wack. Time for a check and a tune maybe.
puddinlegs is offline
post #9 of 13 Old 07-02-2012
Maybe your topping lift was hanging up on something
fkane is offline
post #10 of 13 Old 07-02-2012 Thread Starter
KIVALO's Avatar
Dock
I thought of that and slacked it, no change unfortunately.
s/v KIVALO
2003 Hunter 260
WORK IS OVER-RATED
KIVALO is offline
Stay sail Boom wookie General Discussion (sailing related) 3 12-08-2009 11:48 AM
Mainsail fluttering on 08 Beneteau 40 nika44 General Discussion (sailing related) 22 06-17-2009 07:38 PM
Boom-end sheeting & sail trim bobmcgov Learning to Sail 10 09-25-2007 11:30 PM
Raise Boom/Shorten sail Neicy Gear & Maintenance 8 12-28-2005 11:50 AM
IN BOOM MAIN SAIL FURLING andantesmr Gear & Maintenance 4 07-07-2001 11:49 AM
