Dinghy Plans - Page 2 - SailNet Community
post #11 of 18 Old 07-04-2012
S/V Lilo, Islander 32
I also built a Spindrift from B&B, and we love it! Ours is the 11' model, which nests to just under 6', They have a 10 foot model that would be closer to what you need, but you would still need to be creative to get down to the length you need.
We have two kids, so capacity was a big issue for us. We also used some ideas from other builders to make the bottom of the dingy "clip" together, and only have bolts on the top. This means the two halves will float independently, so we can put it together (and take it apart) in the water rather then on deck which I think makes a huge difference.
Good luck, I'll look forward to hearing what you come up with.
S/V Lilo
1964 Islander 32
Saint Helens, OR
IslanderGuy is offline
post #12 of 18 Old 07-04-2012
Owl
-OvO-'s Avatar
Re: Dinghy Plans
The dinghy in my profile photo (up there at 11 o'clock) is an Eastport pram. You really can't sail it with two adults in it. It is very stable, and difficult to capsize. It rows nicely, but even alone, it doesn't sail all that well. Below 5 knots, or upwind, rowing is faster. Above 10 kts, you start taking water over the square prow (through the handhold), or over the lee gunwale (!!). In between, you're trying to sit in the bottom of the boat because your own body is shadowing the sail. If you try to carry the oars with you while you're sailing, they are in the way. If you try to carry the sailing rig with you while you're rowing, then *it* is in the way. I would consider it primarily a rowing dinghy for very sheltered water with a sail kit that you might use occasionally.
This said, I have had it out on the water during a small-craft warning (with short fetch so maybe 1'-2' waves), and I could still sail with never any danger of capsize, but it was a lot of work and I was constantly bailing.
I do like the looks of the spindrift.
-OvO- is offline
post #13 of 18 Old 07-04-2012
Over Hill Sailing Club
smurphny's Avatar
Re: Dinghy Plans
Those Spindrift designs look very nice. I built a stitch and glue pram a couple of years ago which works ok but the pram design is iffy in any kind of sea. The only thing I use it for is when on a mooring at home in Lake Champlain. I think it would be in danger of swamping in some of the anchorages in my travels. I use a rubber ducky. The pointy bow of the Spindrift looks like a much better idea than a pram. Having a hard hulled dinghy is a good thought but it's nice to be able to fold up the ducky and get it below and out of the way.
smurphny is offline
post #14 of 18 Old 07-05-2012
Barquito
Barquito's Avatar
Re: Dinghy Plans
I will be building a dinghy design by Sam Devlin Devlin Designing Boat Builders - Polliwog. I plant to put this on the foredeck of my B27. I did a scale cardboard mock-up of the dinghy on the foredeck, and found that there will still be some sidedeck available all the way to the bow. The dinghy is long enough that it will go from the mast to just in front of the mooring cleat (I bet your mooring cleat is long gone on your massive re-fit). That will make the central mooring cleat useful for securing the dinghy. I will add cleats on each side of the bow for mooring. I think on a bigger boat I would like to have the dinghy between the mast and the main hatch. Not sure how the boat will perform with this thing on the bow!
Your site is great. Do you have a launch date in mind?
Valiant 32
Barquito is offline
post #15 of 18 Old 07-05-2012
bratzcpa's Avatar
Re: Dinghy Plans
I built a dinghy last year (stitch and glue). Just about 8' long. Rows great and sails well too. Here is a link to my "building blog". It was a fun project, but probably not any less expensive (overall) than a fair RIB.
I've got a 27' Catalina. I do have room to put it up on the foredeck, but it's HUGE looking and acting up there. No single-handed deck-sweeping tacks with the big genoa though.
Usually I tow it, or put on davits on the stern.
~markb
S/V "New Girl" on the dock
Catalina 27
bratzcpa is offline
post #16 of 18 Old 07-05-2012
Barquito
Barquito's Avatar
Re: Dinghy Plans
Looks like the D4. Free plans are availble on the interweb. That was my first dinghy project. I was amazed how stable those things are. You can stand on the very outboard edge of the seat without any problems. I think, in order to heave good stability, the trick is to make sure the beam is no less than about 3'8". Mine ended up being too heavy, however.
Valiant 32
Barquito is offline
post #17 of 18 Old 07-05-2012
Skipper Jer's Avatar
Re: Dinghy Plans
I like the D4, the plans are free, weight is low, can be sailed.
Anyone know if someone has made it into a nesting dinghy?
Skipper Jer is offline
post #18 of 18 Old 07-05-2012 Thread Starter
Bristol 27 Owner
Re: Dinghy Plans
Thanks for all your replies. I will weigh all the input and decide in the next couple months. I'd like to turn my attention to the dinghy soon, so I can have a little boat to take out and practice sailing while the big boat project continues. Speaking of which...
One big thing I've learned from the project is that it's near impossible to estimate the true length of time something will take. Due to this, I've given up any sense of timeline and try to approach each day as the next step, without knowing exactly how many more steps are left. I enjoy the process and once afloat, I hope to look back fondly on the time spent building.
To be more clear, there isn't a specific date in mind, but it will happen one day.
Also, Barquito, I don't think I have your Bristol27 listed on the site. If you're interested in sharing information about your boat I know others and I would appreciate it. I can't private message yet (not enough posts), but can you e-mail me so we can discuss getting your boat on the site? My e-mail is andrew@bristol27.com
<- Follow along as I repair my 1975 Bristol 27 and get it ready for blue water cruising.
avd155 is offline
good light rowing dinghy plans? copacabana General Discussion (sailing related) 26 04-05-2013 07:54 AM
Watermaker Plans Martinini Gear & Maintenance 25 11-02-2010 06:01 PM
Nesting dinghy plans ebreeden Gear & Maintenance 4 11-26-2009 01:12 PM
folding dinghy plans, or modding plans scottyt General Discussion (sailing related) 13 07-12-2009 03:54 AM
PNW: Seattle - 4th Plans artbyjody General Discussion (sailing related) 14 06-27-2008 01:23 PM
