  #1
Old 07-05-2012
bratzcpa's Avatar
bratzcpa is on a distinguished road
Converting stove from alcohol to LPG
Good morning:
All right . . I've had it!!! This is the last weekend I will every monkey around with my alcohol stove. grrrrr. Yep, I'm pretty familiar with how they work and all. I have the exact same stove model on my power cabin boat and its "ok" there. Please don't try to talk me into keeping the alcohol stove - I am truly done with it.
So, I'd like to convert this over to LPG. I've read up on the various safety things (locker, solenoid, etc.) and understand what needs to be done there.
I'd like to keep the same basic "stove body" in place. It has a great setup with moveable fiddles/pot holders, integrated cover/cutting board. In other words I like that part.
I simply want to replace the burners and control knobs.
I've been looking at various LPG camp stoves and think that it "should" be fairly easy to do the replacement. Just wondering if anyone else has done this approach? what stove did you end up using for "parts"? Any tips or suggestions?
thank you,
~mark b
~markb
S/V "New Girl" on the dock
Catalina 27
  #2
Old 07-06-2012
Boasun's Avatar
Boasun will become famous soon enough Boasun will become famous soon enough
Re: Converting stove from alcohol to LPG
Well I would like to replace the electric stove top on my boat.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
  #3
Old 07-06-2012
hellosailor's Avatar
hellosailor has a spectacular aura about hellosailor has a spectacular aura about
Mark, unless the same company sells a conversion kit, I'm thinking that replacing the burners, running the plumbing, doing everything right, is going to be two months worth of futzing around and not being able to use the stove.
I'd look for a simple replacement and resign myself to making a different counter/cover afterwards if that's what it took. Just making a gas locker and installing the lines properly will take up enough of your time.
  #4
Old 07-06-2012
TakeFive's Avatar
Used to be RhythmDoctor
TakeFive will become famous soon enough
Two words: KA BOOM!!!!
Do you really want to mess with this? Solenoids and all that are fine, but do you really want a mickey mouse stove? What if you go put water on to boil, then go to use the head for a couple minutes? If that flame goes out, your boat fills with propane. Do you really want to trust your life to a retrofitted stove that wasn't designed to do what you're using it for?
If the mfg makes a retrofit kit that is specifically designed and tested to do this with your exact stove, then fine. Anything sort of that, and I just hope you're not in my marina.
1998 Catalina 250WK "Take Five" (at Anchorage Marina, Essington, on the Delaware River)
1991 15' Trophy (Lake Wallenpaupack)
  #5
Old 07-06-2012
deniseO30's Avatar
Lies about her age
this would be a good choice.. thermocouple protected also. it's under $300
Brand: Force 10
Model #: 43234 / 4320
I'm sure there are others.. thermocouple protected
You may post attachments
You may edit your posts
Converting Kenyon Stove to Propane Everlong Gear & Maintenance 9 09-07-2012 01:06 AM
Converting Enders Alcohol stove to Propane afrinus Gear & Maintenance 4 06-29-2012 11:54 AM
Converting alcohol stove to gas. bruceyp Gear & Maintenance 25 06-11-2012 02:02 PM
alcohol stove KenD Gear & Maintenance 18 11-12-2009 07:04 PM
Using an alcohol stove Bermuda30 General Discussion (sailing related) 10 09-19-2007 12:11 PM
SEO by vBSEO 3.6.1
