NMEA - Not More Electronics Agony! - SailNet Community
post #1 of 9 Old 07-08-2012 Thread Starter
Newbie Member
I just bought a Raymarine e7 and am trying to get it talking to my 5 year old instrumentation - all Raymarine - wind, depth, speed, autohelm, ST60 multi displays. NMEA 0183 seems to be my choice for communications protocol given the vintage of the other instruments. I wired it all up very carefully, checked all connections - no communications. I remembered to set NMEA IN and OUT on the user setup for the ST60 its connected to, and set NMEA IN and OUT on the E7.
I'm concerned about baud rate - the minimum baud rate on the e7 is 4800 and I cannot find any reference info for baud rate on the other instruments.
Any wisdom or advice would appreciated, unless your slagging RM, personally I have found my setup to be bullet proof, just trying to get the new talking to the old.
Thanks
OldSteveH is offline
post #2 of 9 Old 07-08-2012
Re: NMEA - Not More Electronics Agony!
I'm not all that up on RM tech, but the st60's certainly do Seatalk, so you just daisy chain those together and then go into a seatalk -> seatalkNG(n2k) converter dontcha?
I don't think I'd be messing with 0183 from each instrument, that will get ugly real quick.
xymotic is offline
post #3 of 9 Old 07-08-2012
Steve, it is possible for new equipment to be DOA.
So my first thought would be to test the new equipment, connect it to *one* "known good" NMEA talker and see if you can get it to listen, then vice versa.
Similarly, try connecting the old equipment (or at least, one piece at a time) to something simpe and dumb like an old Palm PDA, or a computer serial port, and see if the old equipment is actually putting OUT NMEA.
Sometimes the problem is simply that "RX/IN" and "TX/OUT" have been swapped, often due to bad diagrams or from too many pieces of equipment not making it clear that "IN" and "OUT" are just different ends of the same cable.
IIRC if you connect a simple DC voltmeter on a 5-12V scale to an NMEA bus, you should see a pulse every time data is sent onto the bus. No pulses? There's no data. A GPS should send a pulse once per second, with the typical GPS output strings.
hellosailor is offline
post #4 of 9 Old 07-08-2012
jsaronson's Avatar
I had a defective E7. Reboot the unit by holding dow the power and menu buttons. The Ray techs will push you to use Seatalk. It should not be necessary but is the best way to get them to help you.
Did you go into SETUP and turn on NMEA on the e7?????????????
jsaronson is offline
post #5 of 9 Old 07-08-2012
Senior Pirate
TropicCat's Avatar
Wasn't the idea behind the E7 to use Bluetooth to stream display data to your ipad or iphone?
Remember NEMA 0183 you can only have just 1 'talker'
Tropic Cat
TropicCat is offline
post #6 of 9 Old 07-09-2012 Thread Starter
Newbie Member
Thanks for replies.
I don't have time to mess with it. I went into the dealer today and ordered cable adapter to connect existing ST to new STNG backbone.
Hopefully that will do it. I don't relish the DOA prospect. The chart plotter is working fine otherwise. And yes I did enable NMEA 0183.
Steve
S/V Diamond Girl
C&C 34
post #7 of 9 Old 07-09-2012
Senior Moment Member
SloopJonB's Avatar
Go back to hanks, a Windex, a leadline, a compass and wood chips dropped over the side.
SloopJonB is offline
post #8 of 9 Old 07-12-2012
Sailboat Reboot
svzephyr44's Avatar
Send a message via Skype™ to svzephyr44
All NMEA '83 is 4800 baud except for the AIS instruments. Autohelm has a wonderful habit on not repeating what it on the input bus on the output bus - like you feed wind into your GPS and it just drops the data. Its a cheap way to get you to buy their seatalk to NMEA converter. Easiest way to test the equipment (presuming you have Windows XP) is to feed the output of each instrument into your com port in HyperTerminal set at 4800-N (no parity) 8 (data bits) 1 (stop bit) It you see it you are getting it! As I remember (but you can google the pin assignments for COM ports) you connect the output of your instruments to pins 2 and 6 on the Com port. I forget which is hi and which is ground but you can only wire them two ways.
Best of luck.
CAPT Roger J. Jones USN (ret.)
Sailboat Reboot
411 Walnut Street, #9700, Green Cove Springs, FL 32043-3443
Reboot's Agent's Email:
Web Site:
Blogging:
Twitter @Sailboat_Reboot
svzephyr44 is offline
post #9 of 9 Old 07-23-2012 Thread Starter
Newbie Member
An update for anyone interested. I installed a Seatalk ng backbone and connected the older instruments (which were already connected together via Seatalk) with a Seatalk ng converter cable. The E7 is now receiving all data perfectly and the autohelm is getting its Track instruction from the E7. Problem is solved.
It pisses me off having to throw money at the problem to make it go away. The NMEA 0183 interface should have worked.
But all's well that ends well and it wasn't that expensive - about $120 for all parts - would have been less but I bought an extra 15ft cable to move the E7 out to the helm.
Steve
S/V Diamond Girl
C&C 34
NMEA 0183 vs NMEA 2000 Dean101 Gear & Maintenance 37 05-30-2014 10:29 PM
Doom, Despair, and Agony on me... Silvio General Discussion (sailing related) 42 03-02-2012 11:44 AM
NMEA 2000 or NMEA 0183 DrB Gear & Maintenance 3 06-22-2010 10:26 PM
nmea protocalls TXS-ALAMO Gear & Maintenance 1 03-09-2007 04:20 PM
Wheelpilot and NMEA stephens84 Gear & Maintenance 2 06-23-2004 06:42 AM
