Name my boat! Balboa 8.2 - Page 3 - SailNet Community
 5Likes
post #21 of 27 Old 07-09-2012
Senior Pirate
TropicCat's Avatar
Re: Name my boat! Balboa 8.2
Originally Posted by cd66312 View Post
My lady friend at the time came up with "Trouble" after seeing it break my wallet a few times. I think she may have been on to something...
Then she proceeded to offer me a "free" chriscraft in need of repairs, Trouble^2?
S/V "Trouble" has a ring to it.
A very Pirate sounding name!
Tropic Cat
TropicCat is offline
post #22 of 27 Old 07-11-2012
Merit25lovers's Avatar
Tipper
Merit25lovers is offline
post #23 of 27 Old 07-11-2012
Originally Posted by kcbiw View Post
Whoa. I suggest you call Rob and the two of you hook up for info. Our boat is in the marina. We were just talking about making a boat trip and I said "Are you fricking kidding? That mast is a nightmare." but that's just me.
Rob is 402-880-7689. He would love to talk to you too.
Does your boat have swept back spreaders? My Aquarius does. I use a stainless A frame stuck into the transom with a roller on top, (like a trailer bow roller).
I pick up the mast top and place on the roller, then go forward and pick up the mast base, and push, it rolls backwards until aligned with the mast step.
Then connect spreaders.
Then bolt into mast step, and connect a come along strap to forestay using a pin & s hook.
Then with one person pushing on the mid mast, (it's at about 25 degs now with extended A frame), the other cranks the come along keeping tension, as the lifter keeps it centered until spreaders engage.
Once the spreaders have enough tension to keep it centered, (there is a bad moment at about 60 degs when the lifter has to be on tippie toe, and there is enough slack on the spreaders to lean about 20 degs.
The come along guy keeps cranking, and the mast straightens up and tightens into position.......whew! it's up.
Connect forestay, ( I keep the lifting pin in place until fixed to the tack plate).
Tighten rigging, then go sailing.
It takes about 30 mins start to finish on mine. And I only have to lift half the weight of the mast.
The only better way I've thought of, but haven't tested yet....Is to build an A-frame out of 2 by 4's that is about 7 or 8 ft tall, and the base would nest in the cockpit corners, and the top would be single bolted about a foot from the end, so when spread it would have about 6 inches for the mast to nest in.
That would be lifted into position about 45 degs up, so the mast would have something to center it until the spreaders engage.
The Sun has Risen on a New Day filled with the Promise of Adventure.
CapnBilll is offline
post #24 of 27 Old 07-11-2012
youmeandthed's Avatar
I vote rocky
Life's a dream, live it!
youmeandthed is offline
post #25 of 27 Old 07-12-2012 Thread Starter
The B8.2 I have does not have swept spreaders.
I have been stepping the mast backwards from how most people do it. I place the boom in the slot and tie a downhaul of sorts, then the back stay to the boom. Now from the tip of the boom I tie a line, which then goes through a block tied to the stern, around a winch a few times, then to the clam cleat on the traveller. Having one person lift the mast, another balances the boom and pulls the line through the winch/cleat setup. All stays remain attached to their final destinations apart from the back stay.
My issue is that I have both the mast and the boom want to go sideways without someone holding them in place, I want to find a way a single person could do this process if need be since I have no slip and go through the process every time I go out.
This is ok with guys, but I would hate to put some poor lady through this situation, it would be a sure way to make sure she never sailed with me again.
cd66312 is offline
post #26 of 27 Old 07-12-2012
Boat: Schrödinger
Dingy: Cat
Boat: Pavlov
Dingy: Dog
benjamen is offline
post #27 of 27 Old 07-12-2012
johnnyquest37's Avatar
Boat: No Woman
Dinghy: No Cry
Boat: Heaven
Dinghy: Stairway
JoeDiver likes this.
[/B]S/V Wind Orchid
Catalina 350 (hull# 273)
Annapolis, MD
LET'S GET SERIOUS ABOUT REMOVING POLITCAL TAG LINES -- NOW!
johnnyquest37 is offline
Balboa 24, $700.00 mtboat Boat Review and Purchase Forum 2 07-01-2011 02:35 PM
First Boat? Any of these: O'Day Mariner, Balboa, or Capri 14.2 jp375 Boat Review and Purchase Forum 22 12-08-2009 08:54 PM
balboa 20? SLObrett Boat Review and Purchase Forum 6 04-13-2009 07:49 PM
balboa 27 rskaug General Discussion (sailing related) 0 11-12-2002 09:25 AM
