New info on a Capri 13 - SailNet Community
post #1 of 8 Old 07-09-2012 Thread Starter
Cool New info on a Capri 13
Just received a used Capri 13 but need rigging info.Help!!!
ldorsey is offline
post #2 of 8 Old 07-09-2012
Re: New info on a Capri 13
do you mean Capri 14 ?
or ?
WDS123 is offline
post #3 of 8 Old 07-09-2012 Thread Starter
It is a 13
ldorsey is offline
post #4 of 8 Old 07-09-2012
bgeddes's Avatar
Have seen this page?
Cyclone 13 Technical Notes
Half way down is a section on rigging.
bgeddes is offline
post #5 of 8 Old 07-10-2012 Thread Starter
I looked at it but still not all theallies to the 13
ldorsey is offline
post #6 of 8 Old 07-10-2012
Did you see the rigging diagram that is included in the link provided by bgeddes? It appears to provide comprehensive info on the rigging. Check it out at the following link:
http://terrenceberres.com/c13rigging.gif
Sailormon6 is offline
post #7 of 8 Old 07-11-2012 Thread Starter
Yes thank you
ldorsey is offline
post #8 of 8 Old 12-31-2012
One question on the rigging for my Capri 13 that I haven't been able to figure out/decide. The tack corner of my sail has 2 grommets. One is obviously for the Cunningham sheet. I was thinking that the lower one would attach to the gooseneck car on my boom to pull or hold the boom more up the mast, however, the hole on my gooseneck is on the bottom of the car not the top. It seems awkward to attach on the bottom, but if I don't the boom sits at a pretty low angle making it hard to clear my forward crew's head. From the diagrams I've found it doesn't look like the boom is attached to the tack corner of the sail at all. Gravity and the boom vang hold it down, shouldn't something hold it up? Is the boom gooseneck supposed to attach to anything to hold it higher up and more perpendicular to the mast? Should I reverse my gooseneck in order to attach the tack of the sail to the boom or is the Cyclone not designed this way? Thanks!
mtleon is offline
Capri 16 Termite Todd Introduce Yourself 0 01-14-2012 07:05 PM
Capri 22 magpie Racing 10 04-20-2011 11:15 AM
Capri 26 olie Boat Review and Purchase Forum 3 08-17-2009 09:19 AM
Who knows about Capri 14.2s? scottbre Learning to Sail 2 06-14-2006 07:49 PM
capri 30 noscreenname Racing 0 12-06-2005 12:29 PM
