cracked hull - SailNet Community
post #1 of 5 Old 07-10-2012 Thread Starter
cracked hull
Hey everyone. Nice forum. I'm still trying to find my way around here so forgive me. I've purchased a sea spray 15 cat. and the hull has some spider webbing in spots but nothing taking on water. I've sanded the clear coat to prep it. Can I put on a layer of fiberglass resin gel to reinforce the hull and should I use fiberglass mesh as well or just the resin? Any help would be greatly appreciated. Sean
sean007 is offline
post #2 of 5 Old 07-10-2012
Re: cracked hull
Consider posting a picture of the areas of concern. This would provide better information on how best to repair.
ambianceack is offline
post #3 of 5 Old 07-10-2012
72 C&C Corvette
CorvetteGuy's Avatar
Re: cracked hull
Sounds like gel coat cracks, think about repairing it with a gel coat repair kit, if its structual then go the way of the glass and resin.
CorvetteGuy is offline
post #4 of 5 Old 07-10-2012
JimsCAL's Avatar
Re: cracked hull
Not clear if its gel coat cracks which is just cosmetic or cracks in the fiberglass itself which is structural. As suggested, some pics would help.
And unlike the paint on a car, there's no clearcoat on fiberglass gelcoat.
JimsCAL is offline
post #5 of 5 Old 07-10-2012
leogallant's Avatar
cracked hull
If you're going to re-gelcoat the affected area...Recently, my son and I did some work on spider cracks on the topside of our Boston Whaler tender. After sanding down to remove hazing and then cleaning with acetone, we used fiberglass reinforced bonds and skim coated it, working it in many directions to get as good a fill in the cracks as possible. We were very pleased with the results once we sanded it down and painted.
Leo
Journey to Charleston on Ubiquitous
Steve's Ubiquitous Blog
leogallant is offline
Cracked hull caused by haul out JapanSailor Gear & Maintenance 37 03-02-2010 05:45 AM
cracked headliner bestfriend Gear & Maintenance 18 01-08-2007 09:55 PM
cracked skeg T37 berwick Boat Review and Purchase Forum 4 01-20-2005 02:27 AM
cracked skeg T37 berwick Gear & Maintenance 3 01-13-2005 07:07 AM
cracked rudder aasault Gear & Maintenance 0 10-10-2001 04:30 PM
