Anchors Away... - Page 2 - SailNet Community
 6Likes
post #11 of 15 Old 07-11-2012
Junior member, rest old
msmith10's Avatar
Re: Anchors Away...
If you don't have a copy, I'd highly recommend Chapman's "Piloting and Seamanship". While I don't see many people referring to it nowadays, when I was growing up it was the bible (and a lot more fun to read). Over my lifetime I've read it many times and still glean useful stuff from it. The chapter on anchoring is a good reference.
With a chain/rope rode my minimum scope is 5:1. In 15-20 knots I'd prefer 7:1 or more. As long as you're not in a crowded anchorage where you have to watch your swing radius, the only downside to more scope is the work in retrieval, which is a lot less than the work in scrambling to reset an anchor in the dark in a storm.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #12 of 15 Old 07-11-2012
johnnyquest37's Avatar
Re: Anchors Away...
Anchoring: Minimum scope is 7:1 for overnight anchoring when using chain/rope rode. This is the ASA standard and believe (will have to check) both "Chapman's" and "Annapolis" use the same ratio. That is seven to one from the stem to the bottom, not seven times the water depth. I generally use 8:1 and if there is plenty of room in the anchorage, I just put all 200' of rode I have out.
We back down on the engine to set the anchor and to test the holding. If I am in slow reverse but not moving, then the anchor is set. We take azimuths to three objects ashore. You have to pick obejcts that will be visable at night, though. For example, water towers are good because they usually have lights on them. Trees are bad - can't see them in the dark. If you suspect you are dragging in the night, shoot an azimuth to these three objects again and if two of them have changed significantly, then you are dragging. Sometimes I will use my chartplotter's track function. I zoom in on the boat's location and with "tracking" on. Over time, the chartplotter will draw a nice circle around the anchor. If the track is showing the boat moving outside the swinging circle, then we are dragging. If you do find yourself dragging, the first thing do (if you have room) is to let out more scope.
[/B]S/V Wind Orchid
Catalina 350 (hull# 273)
Annapolis, MD
LET'S GET SERIOUS ABOUT REMOVING POLITCAL TAG LINES -- NOW!
johnnyquest37 is offline
post #13 of 15 Old 07-11-2012
Re: Anchors Away...
For depth markers on my three strand rope rode I use wire ties looped through one strand. black every 25 feet with a white one at 100 feet. Very cheap but effective.
msmith10 likes this.
saillife is offline
post #14 of 15 Old 07-11-2012
Re: Anchors Away...
Congratulations on the start of great fun and adventures!
Everyone has different equipment so develops different ways of approaching the same issue. We have a handheld GPS, so when the anchor goes overboard we hit the MOB button to mark the spot. (The GPS has a proximity alarm system somewhere but its not easy to use and as others have mentioned too much scrolling through menus. The MOB button is easy) We keep the GPS in the Vberth at night and then if things feel like they are changing we can turn it on and check our position relative to the MOB waypoint.
There is no substitute for an eyes on check but sometimes you just need that little bit of reassurance without getting out of bed!
Have fun!
Tanya
tjvanginkel is offline
post #15 of 15 Old 07-12-2012
SaltwaterSuzi/CapnLarry
LarryandSusanMacDonald's Avatar
Re: Anchors Away...
We've anchored hundreds and hundreds of times and have learned through trial and error and by talking to others who have had more experience. Out take on it is HERE.
Hope this helps. It really works for us. And if you're new to boating, take a look around the rest of the site. We've learned a lot over the many years we've been cruising, and feel, because of the 'pay it forward' mentality of most cruisers, that we should share what we've learned.
Saltwater Suzi and Cap'n Larry
"A sailboat is a fickle mistress. You’ve got to buy her things. You’ve got to understand everything about her. What you don’t know she’ll use against you." -Captain Larry
LarryandSusanMacDonald is offline
How many anchors do you really need? n0w0rries General Discussion (sailing related) 23 04-13-2011 09:40 AM
how many anchors do you need? groundhog Gear & Maintenance 9 08-29-2006 11:18 AM
Using Two Anchors Tom Wood Seamanship Articles 0 01-19-2004 08:00 PM
anchors walt123 Seamanship & Navigation 57 05-01-2003 02:35 PM
