  #11
Old 07-11-2012
HUGOSALT is on a distinguished road
Re: Diesel consumption.
For a rough comparison...
Last May on last leg of trip (Cape Cod Canal to Kittery Me.)
on a friends Hunter 33 with a Yanmar 2GM20, motored entire leg
in benign conditions at 1800-2200 rpm's (average 2000)
18 hours ...close to 75 n miles...used less than .4 gal. per hour
with ave. speed of hair over 4 knots.
Did not tow the dinghy..so comsuption may be close to yours
when you are towing dinghy.
Head wind and sea conditions will seriously impact fuel comsuption.
  #12
Old 07-11-2012
celenoglu's Avatar
celenoglu is on a distinguished road
The consumption for a 30 HP engine at cruising speed is appproximately 1liters/mile
  #13
Old 07-11-2012
copacabana is on a distinguished road
Celenoglu, your calculation of 1 liter/mile seems a little high for a 30 hp engine. I have a 30 hp Yanmar in a fairly heavy 35ft boat and I burn 2 litres per hour at 2300 RPM, giving me 5 to 6 kts, depending on sea state. That means I am getting from 2.5 to 3 miles per liter. What engine do you have and what RPM do you cruise at?
Vindö 50
  #14
Old 07-11-2012
JimsCAL's Avatar
JimsCAL is on a distinguished road
While the prop (and how well it has been sized) has a lot to do with consumption, an average of 1/2 gallon an hour for a 30-35 foot boat cruising at 5-6 knots in calm water is a good number. Note that consumption will increase significantly as you increase speed. And its not linear but roughly a cubic relationship. So reducing the speed (or RPM) by 20% cuts the power in half. That's why using the engine maximum rated power to estimate fuel consumption doesn't work.
  #15
Old 07-11-2012
Boasun's Avatar
Boasun will become famous soon enough Boasun will become famous soon enough
You can be fairly acturate on fuel consumption By taking fuel soundings I.E. by stick or tape, before and after you have used the engine/generator. And tracking the data in an engine log. Over a period of time you will have an excellent idea of how much fuel you have used and what is left on board.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
  #16
Old 07-12-2012
travlineasy's Avatar
Morgan 33 O.I. Perryville
travlineasy will become famous soon enough
I use the GPS/Plotter to determine the distance (over ground) I've traveled, always leave with a full tank of gas, then fill it when I return and calculate the gas consumption of the 30-HP Universal Atomic-4 at 2,000 RPM pushing my 33 Morgan O.I.. On average, it works out to about 12-MPG, which I believe is about as economical as I can expect - especially from a 35-year-old gasoline engine. I figure I have a conservative cruising range on the engine of about 300 miles. About 5 tanks of fuel will easily get me from Perryville,MD to Key West, FL.
My fuel gauges quit working last year, and I'm not about to replace them. I carry 35-gallons of gas in the tank, and now use a 1/4-inch wooden dowel with appropriate markings if I'm worried about the amount remaining in the tank. The stick has only been used on two occasions.
Good Luck,
Gary
  #17
Old 07-12-2012
wescarroll is on a distinguished road
A piece of clear fuel line run from the vent line above the tank to a tap below the bottom of the tank, vertically along the side where it can be easily observed makes a foolproof emergency fuel gauge.
  #18
Old 07-12-2012
cruisingdream is on a distinguished road
Yanmar 3gmf, I use 20gal per YEAR, who needs a fuel gauge! Just raise those big white things & the boat goes.
You may post attachments
You may edit your posts
fuel consumption gas vs diesel jklewissf Gear & Maintenance 25 1 Week Ago 07:28 PM
Fuel Consumption vega1860 General Discussion (sailing related) 17 12-25-2011 11:46 AM
Yanmar 1GM Diesel fuel consumption H216Sailor Gear & Maintenance 15 04-03-2008 08:17 PM
Westerbeke 27 - Diesel Consumption Rate craigtoo Gear & Maintenance 28 03-11-2008 09:18 PM
Fuel Consumption SimonV General Discussion (sailing related) 10 02-14-2007 12:28 PM
SEO by vBSEO 3.6.1
