  #1
Old 07-10-2012
flyingwelshman's Avatar
flyingwelshman will become famous soon enough
Diesel consumption.
My New-To-Me Hunter 30' had a fuel gauge.
The fuel gauge was located on top of the fuel tank.
The fuel tank is conveniently located under the cockpit, between two lockers.
To read (or rather: "attempt to read") the gauge one had to empty a locker, invert one's self (with someone holding one's ankles). In this way one could see the gauge, but not read the fuel level on it.
I spoke to a bunch of people about fuel consumption and most of the responses involved keeping track of hours run (and RPM's) and diesel added. In that way the consumption rate could be established.
Well, Dammit Jim! I'm a cook not a mathematician (or 'electrician' - more on that later).
I decided to install a new gauge attached to a sending unit.
I replaced the old gauge and float with a new float and sending unit and wired it all to a switch and shiny gauge that I inserted into my cockpit coaming.
The damned thing didn't work.
I didn't have time to play around with it as I was heading out for a week and a half with my wife. I was convinced that I was running low on diesel at one point so I reverted to the tried and true technique of inserting a wooden spoon handle into the tank. Worked a treat!
A good friend of mine is an electrical engineer. I asked him to take a look at the new gauge's wiring , determine why it wasn't working.
He was very impressed by my work and said that the installation was perfect except for three 'minor' mistakes.
  1. The connections were not secure - who knew that ring connectors are rated by wire gauge as well as the size of the hole?
  2. The wires were connected to the wrong terminals.
  3. And the polarity was backwards.
Other than that he said I did an expert job.
The gauge seems to be working now.
While the gauge was not working I decided to track the engine hours and try to ascertain fuel consumption rates.
I came up with this engine log. Please let me know if you think it would be useful and if you believe it should have more information.
Thanks.
1989 Hunter 30'
Southern Georgian Bay
'Nautai te salutamus!'
  #2
Old 07-10-2012
blowinstink's Avatar
Call me Ishmael
blowinstink is on a distinguished road
Re: Diesel consumption.
I think you want to add RPMs. If I run at 1800 RPM's (my sweet spot) I get @80% power (approx 5kn) and 2hrs/gal. If I run all out at 2800 RPMs I get 100% power (6kn+) but as little as 3/4hr/gal. You want to track your consumption levels. To do that, you'll need to keep an eye on your engine speed.
.02
Matt
  #3
Old 07-10-2012
.02
Matt
I guestimated about 2 litres per hour at 2000 RPM - that's about 1 gal(US) per two hours - pretty close.
What size engine do you have and what size boat? do you tow a dinghy?
I have a 30' Hunter (9500#'s approx.) and I used to tow a heavy dink. I just picked up a very light RIB (60 #'s) so mileage will go up. I have a 18 horse Yanmar diesel.
1989 Hunter 30'
  #4
Old 07-10-2012
sebez is on a distinguished road
What size and make of engine do you have?
1982 Morgan 321
  #5
Old 07-10-2012
Yanmar 2GM20
Originally Posted by flyingwelshman View Post
I have an 18 horse Yanmar diesel.
1989 Hunter 30'
  #6
Old 07-10-2012
WanderingStar is on a distinguished road
I still use the stick.
  #7
Old 07-10-2012
TropicCat's Avatar
Senior Pirate
TropicCat is on a distinguished road
My 2 engines are single cylinder Yanmar 1GM10s. I use 1 pint of fuel per hour per engine at 2500 RPM. These are in a catamaran, obviously with no lead ballast. Mileage is pretty darn good!!
Tropic Cat
  #8
Old 07-10-2012
MedSailor's Avatar
"Fairhaven" Formosa 41
MedSailor is on a distinguished road
Thanks.
Looks fine, except there's nowhere to record how many gallons you're using. Geez what's the use of it without that!
I think you could also just go by the old rule of 18HP/Gal/HR. Look at your engine manual and see how many HP you're using at your chosen RPM (assuming correctly sized prop) and you'll be really close.
See also this thread:
fuel consumption gas vs diesel
MedSailor
"True, your boat will outperform mine to windward, but my boat will always outperform yours at anchor." --MedSailor
  #9
Old 07-10-2012
BarryL's Avatar
BarryL is on a distinguished road
Hey,
My boat has a functioning fuel gauge. I also have a functioning hour meter. From 6 years of use I know that I use, on average, about 1/2 gallon an hour. This is for a Universal M25 turning a 3 blade prop, and the boat is an O'day 35. I typically run the engine at 80% of max rpm. On my boat that means I move at about 6 kts.
Considering that I use my engine about 50 hours a year I start the season with a fuel tank, fill it again in August, and then at the end of the season.
Real simple.
Barry
Barry Lenoble
Day To Remember, 1986 O'day 35
Mt. Sinai, NY
  #10
Old 07-11-2012
Call me Ishmael
i guestimated about 2 litres per hour at 2000 rpm - that's about 1 gal(us) per two hours - pretty close.
by adding rpm to your sheet, you won't be "guestimating" - you'll know what your consumption is at various power points.
what size engine do you have and what size boat? Do you tow a dinghy?
25hp. 33' boat is about 7-8ton all up. Tow dink sometimes.
My point was / is that by tracking the actual consumption you will get to know what *your boat* consumes.
-m
You may post attachments
You may edit your posts
fuel consumption gas vs diesel jklewissf Gear & Maintenance 25 2 Weeks Ago 07:28 PM
Fuel Consumption vega1860 General Discussion (sailing related) 17 12-25-2011 11:46 AM
Yanmar 1GM Diesel fuel consumption H216Sailor Gear & Maintenance 15 04-03-2008 08:17 PM
Westerbeke 27 - Diesel Consumption Rate craigtoo Gear & Maintenance 28 03-11-2008 09:18 PM
Fuel Consumption SimonV General Discussion (sailing related) 10 02-14-2007 12:28 PM
SEO by vBSEO 3.6.1
