Reefing question - new sailor - SailNet Community
post #1 of 4 Old 07-10-2012 Thread Starter
Wondered if I could get some help. I'm new to sailing and boating in general, having just purchased a 1983 Islander Bahama 30. It has a Kenyon boom, and I'm unclear about the whole reefing setup. The boom has a cam lock near the front for the reefing line, and it goes thru the boom and out the back, over a block/pulley.
I see the reefing clew on the main, I'm just not sure, does the line tie directly to the clew in the main, or does it go thru the clew and back around the boom?
There are no cleats on the boom underneath the reefing clew, and no signs that any ever existed. In the owners manual it looks like the reefing line comes down to the boom, but I'm not at all sure how? The foot of the mainsail is loose, so it would be possible to go around the boom, but then what?
cadteach is offline
post #2 of 4 Old 07-10-2012
Sabreman's Avatar
Re: Reefing question - new sailor
Yes. The line from the forward end of the boom goes aft, exits the boom, goes through the block, through the reef clew, and then back down to the boom to an eye. It sounds like an incomplete installation. The block/eye should be a few inches aft of the clew forming about a sixty degree angle when under tension.
Sabre 38 "Victoria"
Sabreman is offline
post #3 of 4 Old 07-11-2012
JimsCAL's Avatar
Since the main is loose footed, you could just tie the end of reefing line around the boom. Won't work as well as having an eye, but will be OK until you get around to putting them on.
JimsCAL is offline
post #4 of 4 Old 07-11-2012
ASA and PSIA Instructor
Read this tread
Reefing, Spiral Lacing vs single line and how to tell what you've got?
sailingfool is offline
Campbell Sailor Brand Prop Question dacap06 Gear & Maintenance 10 04-30-2013 10:04 AM
Roller Reefing Question... MedSailor Gear & Maintenance 2 06-17-2010 09:05 AM
Sizing reefing lines question josrulz General Discussion (sailing related) 6 03-01-2010 12:08 PM
Reefing Question Stu01 Gear & Maintenance 6 05-27-2008 09:15 PM
Yet another reefing line question saltypat Gear & Maintenance 7 11-06-2007 03:32 PM
