Minimum Depth For Slip? - Page 2 - SailNet Community
 6Likes
post #11 of 29 Old 07-15-2012
Re: Minimum Depth For Slip?
Originally Posted by Melrna View Post
If the wind picks up and waves are formed you will pile drive the keel into the boat. Even wakes from the power boater's will do this. I have 2 friends that lost their boats this way.
Your boat shouldn't rest on the keel when on the hard. It should be resting on the pads, which are placed under the bulkheads that hold the weight of the boat. You will weaken the structural grid which the keel is bolted on, if you continue to place all the weight on it.
I would find another marina.
I agree with Melrna that if the bottom is hard and there is lots of waves/wakes that there is a good possibility of damage. With a soft bottom, I think one would be safe.
I don't agree that the weight of the boat is supported by the pads. At least not in the boat yards here. When they pull a boat, the travel lift lowers it down on some wood blocks on the ground and places the weight of boat on the blocks through the keel. Then, while the boat is still held/steadied in an upright postion, yard workers place/adjust the pads on stands around the boat to keep it upright.
SVAuspicious likes this.
NCC320 is offline
post #12 of 29 Old 07-15-2012 Thread Starter
Great information everyone.
i am in a little protected cove that doesn't get much wave, wind, or wake action. A knucklehead jet skier once in awhile. it is a private cove, no wake area.
i would definitely not keep the boat here if i thought there was any chance of the keel getting pile driven in to the bottom. good point.
i am pretty sure that entire weight of boat is supported by keel when they haul out. I have watched this process many times, and it appears that the jack stands are just used to keep the boat upright.
i will not keep the boat here if keel is resting on hard bottom.
we have minus tides this week, and i am going to measure depth at that time to see where i am really at.
i'm going to dive my slip this morning and probe the bottom to determine the depth of the mud.
i am a technical scuba diver, and would have no problem diving below my boat every month to dig and keep keel clear of mud. i wouldn't dredge whole slip, just where keel is.
if i go for it, and it becomes too much of an inconvenience, or potentially can damage the boat, i will move it.
one thing i failed to mention is that i had a pretty serious motorcycle accident last year. it has been 11 months, and i am still in a walking cast. the ramp, parking, and docks are very easy to negotiate. hopefully cast comes off soon, but i know it will never fully heal, and i do like this marina because of the ease of access.
thanks again for everyone's input.
Blair
Pacific Beach, CA
BlueWaterBlair is offline
post #13 of 29 Old 07-15-2012
I've seen boats resting on their keels in soft mud. I've also seen boats ink, 1. there was an old piling under the slip that puctured the hull on a low low tide. 2. It sunk so deep into the mud the keel stuck, and the boat flooded the next high tide. Other boats the same time were sitting on their keels so I don't know why this one didn't refloat.
The Sun has Risen on a New Day filled with the Promise of Adventure.
CapnBilll is offline
post #14 of 29 Old 07-15-2012 Thread Starter
Bill,
Dang, that isn't good.
i have dove my slip many times, and there is nothing down there.
i really don't want my keel in the mud. if i can't keep it clear, or there is hard ground right under the mud, i will not keep it here.
i'll have a better idea after i dive it today, and measure it at a negative tide this week.
Blair
Pacific Beach, CA
post #15 of 29 Old 07-15-2012
You said you can dive and dredge the slip. Will the marina owners, the city or the state allow you to dredge out the mud. You may find you are in violation of environmental clean water laws. I am not familiar with the laws in your area but, in many areas you need permits to move any silt.
Take care.
killarney_sailor likes this.
s/v Odyssey
Catalina 30
glassdad is offline
post #16 of 29 Old 07-15-2012 Thread Starter
GD,
good point. thanks.
currently i have to clean bottoms every 3-4 weeks. i would just take a couple of 5 gallon buckets down there with me every month, and clear it around the keel.
Blair
Pacific Beach, CA
post #17 of 29 Old 07-15-2012
Smile Re: Minimum Depth For Slip?
I had a sailboat in a slip where I would bottom out with low tides, north winds, etc. Even worse was getting out and finding that a few hours later we couldn't get back in. The bottoming out didn't hurt the boat (soft mud), but it sure didn't make going sailing much fun.
My advise would be to get a shallow draft boat or move to a deeper slip. We did both, and it certainly makes going for a sail more enjoyable:
algee is offline
post #18 of 29 Old 07-15-2012
davidpm's Avatar
Also you should consider the possible effect on you rudder.
Some rudders are very close to keel depth and they are less tolerant of touching bottom
The other outlying possibility is that depending on storm activity tides can be two or more feet higher or lower once every year or two.
davidpm is offline
post #19 of 29 Old 07-15-2012
I've found that keels that are consistently close to the bottom get more fouling growth. Of course, it sounds like you're in a position to dive to clean any growth. On the plus side, powerboat marinas are less attractive to birds than sailboat marina are, so you'll have less to clean from the topsides.
Quickstep192 is offline
post #20 of 29 Old 07-15-2012 Thread Starter
dang, never even thought about the rudder.
guess i have more research to do.
funny about the birds liking sailboats more.
Blair
Pacific Beach, CA
Digi-Depth 99 Depth Sounder sdumo Electronics 0 12-04-2011 02:06 PM
minimum required mooring depth ramminjammin Gear & Maintenance 7 05-02-2008 12:43 PM
Minimum Tankage sab30 Boat Review and Purchase Forum 10 11-05-2007 10:19 AM
Slip Sub-Lease via Slip Renter KeelHaulin General Discussion (sailing related) 4 06-26-2007 12:50 AM
Minimum winch sizing? GC20Squid Gear & Maintenance 2 04-09-2006 07:21 PM
