Like Tree4Likes
  #11
Old 07-16-2012
davidpm's Avatar
davidpm is on a distinguished road
Re: Bottom paint etc
Originally Posted by tommays View Post
HOW big a can of worms does he want to open ?
No matter how good the blaster it will distrub stuff you cant see that will have to fixed
What do you have in mind exactly.
I thought soda blasting did not do damage, apparently it does?
  #12
Old 07-16-2012
tommays's Avatar
In Seafevers refit the ONLY thing NOT FUBAR was the Barrier coat under the 20 layers of bottom paint
I had a tight budget and 5 to 6 days of HELL scraping was worth the 2K
Its NOT like when the blaster is done its barrier coat ready
chrisncate likes this.
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
  #13
Old 07-17-2012
BarryL's Avatar
BarryL is on a distinguished road
Hey,
From what I have seen, soda blasting will not damage gelcoat (unlike SAND blasting, which can really chew up gelcoat). The soda can remove bondo and other types of fillers. If you have patches of that on the keel or hull the soda blast can remove them. It can also open up blisters. It's up to you to decide of that is good or bad.
Barry
Barry Lenoble
Day To Remember, 1986 O'day 35
Mt. Sinai, NY
  #14
Old 07-17-2012
patrscoe's Avatar
patrscoe is on a distinguished road
In reference to the soda blasting causing damage, like everything else, if you hire someone who knows what they are doing and does it everyday, you will not get any damage to the hull. Our guy, although had a poor work ethic, did a okay job and I wish he took a little more off because I still had a lot of sanding to do after he was done.
Patrick
S2 11.0A 36'
Kinsale, Va
Tanzer 16'
Moseley, Va
  #15
Old 07-21-2012
davidpm's Avatar
Beautiful looking job.
After the soda blasting what did you have to do?
I'm assuming sanding?
How much?
You may post attachments
You may edit your posts
Don Casey: Paint Waterline Stripe with Bottom Paint asdf38 Gear & Maintenance 21 05-29-2012 01:09 PM
Bottom paint prep, chipped paint josrulz Gear & Maintenance 16 02-14-2010 08:24 PM
Which Bottom Paint? WhatTheFoley Gear & Maintenance 2 08-24-2009 03:57 PM
Bottom Paint 1, Me 1 BarryL Gear & Maintenance 16 02-23-2008 10:39 AM
Bottom Paint garrettav8or Gear & Maintenance 2 07-24-2004 06:16 AM
SEO by vBSEO 3.6.1
