cracked spreader - SailNet Community
post #1 of 5 Old 07-16-2012 Thread Starter
jkiser's Avatar
cracked spreader
i have wooden mast and i have cracked a spreader the boat is a cheoy lee 33 i hope someone may have a suggestion on replacing one without pulling the boat out of the water
jkiser is offline
post #2 of 5 Old 07-16-2012
Re: cracked spreader
Post this on Gear and Maintenance. That said I don't see why you couldn't loosen the uppers and safely climb the mast to remove the broken spreader.
peterchech is offline
post #3 of 5 Old 07-16-2012 Thread Starter
jkiser's Avatar
will do thanks
jkiser is offline
post #4 of 5 Old 07-16-2012
Senior Cruiser
sea_hunter's Avatar
Dito +1
sea_hunter is offline
post #5 of 5 Old 07-16-2012
Aspiring to be a Mexican
sww914's Avatar
Be sure to rig a halyard or two to support the mast before you pull the shrouds loose.
sww914 is offline
cracked hull sean007 General Discussion (sailing related) 4 07-10-2012 11:14 AM
Cracked Rudder weephee Gear & Maintenance 15 07-19-2010 07:26 AM
cracked skeg T37 berwick Boat Review and Purchase Forum 4 01-20-2005 01:27 AM
cracked skeg T37 berwick Gear & Maintenance 3 01-13-2005 06:07 AM
cracked rudder aasault Gear & Maintenance 0 10-10-2001 03:30 PM
