'86 Hunter 34 halyards - SailNet Community
 1Likes
  • 1 Post By leogallant
post #1 of 5 Old 07-16-2012 Thread Starter
Hunter 34
Making the jump from day sailers to cruiser. Looked at the Hunter and afterwards wondered about the mast mounted main and jib halyards. Once the sail is set would I leave the halyard winched and cleated or would I disengage the halyard from the winch and then cleat. It would seem that if you take it off the winch you would loose tension.
Genkigary is offline
post #2 of 5 Old 07-16-2012
leogallant's Avatar
You want to leave it on the winch so you can handily "Ease the Main" with the advantage of the winch. Relieves a lot of stress from the cleat, too.
RobGallagher likes this.
Leo
Journey to Charleston on Ubiquitous
Steve's Ubiquitous Blog
leogallant is offline
post #3 of 5 Old 07-17-2012
JimsCAL's Avatar
Re: '86 Hunter 34 halyards
It depends. As long as the winch is "dedicated" and not needed by other lines, you can leave it on. On my boat, the lines are led to the cockpit and the cabintop winch serves several lines. Clutches allow the lines to remain tensioned when released from the winch. If you have a cunningham, you can cleat the halyard and then adjust luff tension with that.
JimsCAL is offline
post #4 of 5 Old 07-17-2012
I will disagree with JimsCAL. The main Halyard and cunningham adjust different parts of the luff tension. The cunningham asjust the lower portion of the sail, maybe lower 1/4 to 1/3. On my H34 I use the clutch to contro the halyard.
Mark1948 is offline
post #5 of 5 Old 07-17-2012
JimsCAL's Avatar
Don't disagree with your comments Mark. However I have sailed on several boats that do exactly what I described. Raise the sail to the top of the mast, cleat the halyard off, then tighten the luff with a cunningham. This works fine especially on full-battened mains with limited adjustability for draft and smaller boats that don't even have a main halyard winch.
JimsCAL is offline
Where to run the halyards jarcher Racing 11 04-21-2010 10:24 AM
Fwd: [hunter] boat 1979 Hunter for Sale $9,900 located in Florida NewsReader Mass Bay Sailors 0 08-25-2006 12:15 PM
Replacing Halyards capttb Gear & Maintenance 11 04-23-2004 09:07 AM
Halyards sail-away Gear & Maintenance 2 06-11-2001 03:49 AM
