Gettin' my Helix on, o-----//- - Page 2 - SailNet Community
 4Likes
post #11 of 23 Old 07-27-2012
NCB
Re: Gettin' my Helix on, o-----//-
Reef - I've been following your posts on SN. I'm in Upper Chesapeake as well with a Helix anchor on my porch awaiting installation and much like you I am desperately seeking advice on best way to install. Any chance you'd want to work together on this and help each other out? I've got a 20' bow rider and a 9' rib that we could use to aid installation.
NCB is offline
post #12 of 23 Old 07-27-2012 Thread Starter
Scurvy Dog
Reef33's Avatar
Hi NCB! That sounds great. Heck, you might even be my neighbor? Anyway, my project is at a roadblock. Turns out my brand new SCUBA tank failed inspection and I have to send it back to the manufacturer. So I don't know how long it will take to get a replacement.
Just my luck, the tank inspector said he has only failed 2 tanks in the last 5 years, and one was mine. I don't know if you want to work with me with that kind of luck? Anyway, I can't proceed until I get my tank, so I may not even get it in this year. I will let you know. Thanks, and happy sailing!
Scourge of the Upper Chesapeake since 1993.
Reef33 is offline
post #13 of 23 Old 07-27-2012
Renting a tank is pretty cheap.
Jeanneau 54DS
Minnewaska is offline
post #14 of 23 Old 08-07-2012
NCB
Sounds good Reef. Why don't you PM me (I can't send a PM yet, not enough posts) and we can exchange contact info and see just how close we are to one another.
NCB is offline
post #15 of 23 Old 08-07-2012
Me too, me too
I am also in the Upper Chessie and I am interested in installing a helix. Haven't bought one yet but have been thinking about it. There was a thread maybe a year ago that showed how someone installed one from a boat. He used Schedule 40 PVC pipes and turned the helix from the boat.
Oh, this may seem obvious, but if you do it this way, do NOT install the chain at the end, but before you put the helix into the water!
Please keep us all informed about your experiences. Thank you.
MastUndSchotbruch is offline
post #16 of 23 Old 08-09-2012
Otter
DivingOtter's Avatar
Feel free to give me a call guys. 732.664.2979. Id be happy to give you some info..
DivingOtter is offline
post #17 of 23 Old 08-16-2012 Thread Starter
Scurvy Dog
Reef33's Avatar
So Sorry folks, I have been dealing with other non-sailing issues. I don't know if I will be able to get to this before the water gets too chilly. Will let you know if I do.
Reef33 is offline
post #18 of 23 Old 08-19-2012
Otter
PSSSH! Thats why I have hot water suits. Otter dives tropical during the brutal northeast winters
post #19 of 23 Old 08-13-2013 Thread Starter
Scurvy Dog
Reef33's Avatar
Smile Re: Gettin' my Helix on, o-----//-
If anyone is still interested, after much trial and tribulation, I finally got my Helix installed. I'll summarize here to help anyone else who might attempt this.
The Tackle: I have the 4 foot long, 8 inch disc Helix model # H0848. Used a 3/8" high grade (G70) galvanized chain that was on sale at WM for my bottom chain. (first photo)
The Setup: Found out that a 1/2" shackle opening will not fit over the 1" thick eye on the Helix. So the smallest shackle that you can use is a 5/8". However, the pin from the 5/8" shackle will not fit through the link in the 3/8" chain. So I ended up connecting the 5/8" shackle to the Helix, then connecting a 1/2" shackle to the 5/8" shackle, then connecting the 1/2" shackle to the 3/8" chain. (second photo) Got all that? I mail-ordered Crosby Shackles instead of the cheap Chinese crap that everyone around here sells. I suppose you could use a larger bottom chain which the 5/8" shackle pin would fit, then you would only need one shackle.
Used a 5' long 3/4" iron pipe that I had lying around as leverage for screwing the Helix. (third photo)
Attached the 1/2" shackle to the end of the bottom chain and moused it. Attach the 5/8" shackle to the 1/2" shackle but do not tighten or mouse it. You'll need to take it off again on the bottom when attaching the chain to the Helix. (4th photo)
Dive #1: I did this in two dives because my shackles hadn't arrived yet and it was D-day (weekend off) for the install. I won't go into the diving details except to say make sure you have enough ballast to keep you on the bottom while working, and that moron idiot Maryland stinkpot boaters have no idea what a dive flag means I can't tell you how many times I was buzzed by some inbred 3rd grade dropout with their 15 Honey Boo Boo family members in a 12ft boat out tubing and when you surface to wave them off they just wave back at you with their 3-tooth grin and come even closer to see what you're doing. Sorry, I'm a tad peeved.
Anyhoo, I swam out with the Helix and 5' turning bar to my desired location. Floating them out on a raft is helpful. I used my water toy raft that has a tough cover on it. I anchored this with a small anchor and attached my dive flag to a pendant buoy nearby. Going down about 10 feet I found a muddy clay type bottom. Using the bar I turned the Helix into the bottom. It went in easily, but with satisfying resistance. I did not hit any rocks (thank goodness). The only difficulty that I had was fighting the tide and that I didn't have enough ballast and kept trying to float to the surface. I actually held myself down with the Helix and the bar. I eventually got it turned all the way down so the eye was at "ground level", even a little below (as recommended).
I had put a small float and some 1/4" line in my BCD pocket to attach to the Helix eye to mark the location and I now tied this onto the eye. If you don't mark the location, and you have to come up for anything, you will NEVER find it again. That Helix eye on the bottom is like the proverbial needle-in-a-haystack. Once topside again, I tied a larger crab-pot float on the marker line. Oh, and don't forget your iron pipe. That's the end of dive #1.
Sorry, no pictures of the dive, but put a brown paper bag over your head and that is exactly what you will see in the Chesapeake Bay. Everything you do is done by touch, visibility is about 6 inches in the bay. (to be continued)
IMG_0356 (800x598).jpg   IMG_0378 (800x598).jpg   IMG_0370 (800x598).jpg   IMG_0383 (800x598).jpg
Reef33 is offline
post #20 of 23 Old 08-13-2013
Originally Posted by Reef33 View Post
......I can't tell you how many times I was buzzed by some inbred 3rd grade dropout with their 15 Honey Boo Boo family members in a 12ft boat out tubing and when you surface to wave them off they just wave back at you with their 3-tooth grin and come even closer to see what you're doing. ......
Classic.
Jeanneau 54DS
Helix Mooring Maintenance ambianceack Gear & Maintenance 16 07-13-2012 02:29 PM
Tiki 30 Gettin It Boatsmith General Discussion (sailing related) 1 04-18-2011 06:32 PM
Gettin Close To Full Time CubaLibre Introduce Yourself 4 05-21-2010 12:54 AM
First sail of the season... I'm gettin' old primerate84 General Discussion (sailing related) 10 05-18-2010 06:51 PM
Wow, I'm gettin' a Pudgy! smackdaddy Seamanship & Navigation 24 05-14-2010 06:54 PM
