New guy with dumb questions. - Page 2 - SailNet Community
 9Likes
post #11 of 32 Old 07-17-2012
Sailboat Reboot
svzephyr44's Avatar
Send a message via Skype™ to svzephyr44
Re: New guy with dumb questions.
Do you really want to climb the mast? Are you planning on doing it often? On small boats with deck stepped masts (in other words the mast doesn't go through the deck to the inside of the boat) it is usually easier to take the mast down to work on it then hang there in mid air. On bigger boats - and keel stepped masts - it may be easier to climb (e.g. be winched up - which is not an easy thing if you are a typical adult male for the guy on the winch - a lot of us use the anchor windless for power.) For those of us who single hand and do offshore sailing a frequent solution is to install steps on the mast or use a climber (basically a device that allows you to haul yourself up) in case something goes wrong when you are at sea that you have to fix. Or just to go up and sit on the spreaders to enjoy the view.
With respect to older boats - go down to the FL Keys - you will find hundreds (I am sorry to say) abandoned fiberglass boats that go back to the early seventies.
CAPT Roger J. Jones USN (ret.)
Sailboat Reboot
411 Walnut Street, #9700, Green Cove Springs, FL 32043-3443
Reboot's Agent's Email:
Web Site:
Blogging:
Twitter @Sailboat_Reboot
svzephyr44 is offline
post #12 of 32 Old 07-17-2012
Senior Slacker
SlowButSteady's Avatar
A 27-foot boat is usually right at the cusp of the mast climbing verses mast lowering tradeoff. Much smaller and the boat gets too "tippy" with someone near the top of the mast. Much larger and raising/lowering the mast can be a real chore (and somewhat dangerous to boot). If you decide to climb the mast be very very careful. The fall is no big deal, but that sudden stop at the end is a real bitch. If you decide to lower the mast be very very careful. Everything has to be rigged properly, and you really need to do everything in just the right sequence once you get up to that size of a boat/mast. Screwing up during the mast raising/lowering is probably less likely to result in serious injury than falling from the mast, but it is very likely to rip a hole (or holes) in the deck if the mast topples over to the side.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #13 of 32 Old 07-17-2012
Senior Slacker
Originally Posted by bljones View Post
No, it means they're not really dumb, because they are smart enough to ask. Really dumb people don't ask questions, they just ask you to hold their beer.
Huh?.....what?......did you say something?....
post #14 of 32 Old 07-17-2012 Thread Starter
Thanks for the quick replies....
Yes, I'm referring to fiberglass boats. And while I may have dumb questions, I'm smart enough to stay away from wood boats
It just got to the point where some of the stuff I was reading made it seem like every boat out there that was older than 10 years old was absolute junk... I've mostly owned older boats myself and have had zero issues with hulls. Then again I've never kept a boat in full time. Just wondering why I never heard these lamentations before....
And the mast thing is a funny question, but I've broken just about anything on a boat that can be broken, and I've repaired quite a few things on (and IN) the water. But when there's something hanging out 40 feet in the air I couldn't happen to wonder "well what happens if something up there breaks?"
pilotman is offline
post #15 of 32 Old 07-17-2012
I'm not sure what forums you are reading, but my overall impression of sailnet....there's a lot of us with older boats here and I don't recall any "old boat bashing".
My boat is an '87 and I would guess, the typical sailnetter boat is in the 10-20 year range. Obviously some are newer and some are older and some, a lot older.
Catalina 34
chuck53 is offline
post #16 of 32 Old 07-17-2012 Thread Starter
sorry... didnt mean this site. that was just an impression i got from reading in general.
pilotman is offline
post #17 of 32 Old 07-17-2012
steveg353's Avatar
1982 34 ODay here and the hull is strong. Don't be as concerned about the age of a solid fiberglass hull but be more concerned about previous owners maintenance.
Well maintained hulls on good old boats will outlive us all.
steveg353 is offline
post #18 of 32 Old 07-17-2012
damm bj! sometimes i find myself agreeing with you[in spite of myself].....
sawingknots is offline
post #19 of 32 Old 07-17-2012
itsaboat's Avatar
Well maintained or not, they will outlive us somewhere. In a yard or at the bottom, they will be there.
Pearson 27
itsaboat is offline
post #20 of 32 Old 07-17-2012
I think you've received several good answers to your good questions.
Hull rot, is probably better phrased as a wet core layer between fiberglass. It can be an issue and you don't want a boat that has it. Certainly, not all do.
If the rigging is in good shape, it is taking a much larger load than you would put on it, so up you go. Despite the size of the boat, going up a mast is dangerous and you should follow good safety procedures. Then, when you get there, its a real pain to do any work. Dropping the mast is a much safer and much easier way to work, if practical.
Why don't you hear and concern over condition from power boaters? I have some good answers that will wait until you are fully indoctrinated. However, sailboats are often used in more challenging conditions and perhaps their owners are that much more focused on condition. Secretly, every sailboat owner daydreams about circumnavigating with their boat.
Jeanneau 54DS
Minnewaska is offline
Really dumb question.... Mizu General Discussion (sailing related) 52 01-24-2011 05:26 AM
Brand New Here...Couple Dumb Questions punjabi Cruising & Liveaboard Forum 10 07-18-2007 04:07 PM
Could be dumb, but I'm asking anywho poopdeckpappy General Discussion (sailing related) 32 12-17-2006 10:28 AM
