how to hook up manual pump - SailNet Community
post #1 of 5 Old 07-17-2012 Thread Starter
Huck
smallboatlover's Avatar
Ok so i just realized i have a manual bildge pump i wasn't sure what it was then i put 2 and 2 together and now i know what it is it isn't hook up right now but my question is how to hook it up. were do i put the hose to suck up the water just put it sitting on the lowest part of the boat inside? And does this mean i don't have to hook up the amotomatic bilge pump? or should i have both?
16' mistral sailboat, And 27' coronado
smallboatlover is offline
post #2 of 5 Old 07-17-2012
Senior Cruiser
sea_hunter's Avatar
Um, yes both would be good. They employ 2 different through hulls though.
sea_hunter is offline
post #3 of 5 Old 07-17-2012 Thread Starter
Huck
Well i already have the through hulls. They go to the motor well and then a through hull off the boat.
post #4 of 5 Old 07-18-2012
Senior Cruiser
sea_hunter's Avatar
Above the waterline? The pickup tube for the hand pump will be in the lowest spot in the bilge along with the electric auto/manual pump.
post #5 of 5 Old 07-18-2012
Lake Superior Sailor's Avatar
Re: how to hook up manual pump
I have mine set up in the cockpit so I can use in under-way it pumps from the lowest point of the boat and I use it as my primary pump! It is screened with brass pick-up. My second pump is electric with a float switch ,it's set half-way up the keel just above the lead. My third pump is set up on the cabin sole,also with a float switch ,only this one pumps out on the cockpit floor so you know you have a problem. My yanmar YSM 8 has the provision of pumping off the cabinsole in a real emergency! Remember to keep your boat clean or all the pumps are useless!....Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
Macerator or manual pump? Blissopia Gear & Maintenance 18 01-10-2012 07:25 PM
cw manual bilge pump, bike pump type b40Ibis Gear & Maintenance 2 04-27-2011 08:26 PM
manual bilge pump billdre O'Day 1 05-19-2010 09:39 PM
Manual Bilge Pump backcreeksailor Gear & Maintenance 13 04-18-2009 02:02 AM
manual oil pump wumhenry Gear & Maintenance 3 07-02-2007 03:35 PM
