Delamination. - SailNet Community
 2Likes
post #1 of 12 Old 07-19-2012 Thread Starter
utchuckd's Avatar
Delamination.
When discussing delamination, is it only in reference to the hull/fiberglass? I looked at a boat today that, even though the decks were pretty solid when tapped, had a lot of what I would call delamination in the wood inside. The layers are just coming apart. Is this a major problem itself? Or maybe a symptom of something else? Here's some pics from a couple bulkheads and shelf supports along the cabin:
Also, though most of the bilge was dry it had a big old chunk of rust over a couple keel bolts (if you can make it out). What do you think, run from it?
utchuckd is offline
post #2 of 12 Old 07-19-2012
Re: Delamination.
This type of delamination happens when things leak. Port windows, toe rails, hull joints.
Chances are the deck has some unsound areas but that doesn't mean the boat is toast.
IMHO, she's a project boat. Keel bolts, can't help you with that one. That was the one thing I was concerned about on my sabre but after rebedding the bolts, with the exception of one, they looked good & I was able to torque all of them down without them spinning, which is a good thing.
I'm not happy unless I'm complaining about something.
I'm having a very good day!
misfits is offline
post #3 of 12 Old 07-19-2012
Jetexas's Avatar
Re: Delamination.
The boat was probably full of water at some point. Just know you will have to replace all that plywood, and if you don't, it will stink like mildew forever.
I had to do it on my boat, but for the price it was worth it.
Jetexas is offline
post #4 of 12 Old 07-19-2012
Over Hill Sailing Club
smurphny's Avatar
Re: Delamination.
It does look like moisture damage. Poke around with a small, thin knife to check for rot. If it's "punky" and soft, it's a large problem. If it's just the top veneer that has peeled, I would think about getting some matching veneer and glueing it on, leaving the old plywood. You could also use Git-Rot or similar epoxy (West makes a similar product) if there is a bit of rot and relaminate the veneer.
The rust in that pan may be nothing but residue from something that sat there and rusted. Looks like a pan was glassed in over the bolts. A deeper exam needs to be done to check that the bolts aren't all electrolycized.
smurphny is offline
post #5 of 12 Old 07-19-2012
Re: Delamination.
Delamination is not just fiberglass - it applies to any laminated material (any material where multiple layers are bonded together to form a single unit). Laminated bows, for example, are very common in archery....
But back to your boat. The plywood has been soaked; some of the layers have swollen/shrunk/delaminated, the glue has failed. Plywood which has suffered this abuse rarely returns to its original dimensions, frequently suffers from rot, and generally has lost its structural integrity. Occasionally - rarely - the top laminate layer (veneer) detaches, and as this layer is principally decorative it can be replaced.
The top photo looks like longer-term water penetration, and looks bad.
The other areas may be fixable; in the middle photo it would probably be quicker, easier and more attractive to replace the wooden facia/front. It the third photo (assuming the wood is sound) veneer would probably fix it.
paul323 is offline
post #6 of 12 Old 07-19-2012 Thread Starter
utchuckd's Avatar
Re: Delamination.
Thanks all. I did poke around some with my knife and it seemed dry everywhere, but like y'all said,it has been wet at some time. Just didn't know if this was a seal up anything that leaks and repair/replace the wood, or if it was indicative of some larger problem. The chainplates look to have been replaced, so maybe it's already been taken care of.
utchuckd is offline
post #7 of 12 Old 07-19-2012
Dirt Free
boatpoker's Avatar
Re: Delamination.
Don't even consider this boat until the glass is removed from the keel bolts and they are closely inspected. Replacing keel bolts on most boats is extremely expensive and and almost impossible on others without replacing the keel. It would help to know what model you are talking about.
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
post #8 of 12 Old 07-19-2012 Thread Starter
utchuckd's Avatar
Re: Delamination.
Cal 2-29.
utchuckd is offline
post #9 of 12 Old 07-19-2012
Dirt Free
boatpoker's Avatar
Re: Delamination.
Don't see too many Cal's up here in Canada but I think you'll find that the keel is integral to the hull mold, therefore there are no keel bolts but they did have a steel beam for mast compression support and there is a very good chance that it is badly corroded.
SloopJonB likes this.
I can do that
- wg
post #10 of 12 Old 07-20-2012
tommays's Avatar
Re: Delamination.
On the Cal 29 the rust is from the lifting hoops they used to place the lead in the keel
However the other rust is also from the mild steel mast step which is doused with water from the pan drain in the head area, cooler drain and the original leaking mast wires which funneled water directly to to the top of the beam
If you look under the settee by the compression post you will most likely see a big rusty metal tab
The wood deal is endless bow to stern
But all my important stuff was still alive
And IHMP they fall into the boat worth saving IF your up to 2 years or so work
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
Hull Delamination fastforward26 Gear & Maintenance 17 01-04-2011 07:54 PM
delamination, fix the deck jwjab Gear & Maintenance 3 07-08-2010 12:31 PM
Fixing delamination brainiac Gear & Maintenance 6 05-05-2010 08:05 AM
Delamination Erwan Gear & Maintenance 6 11-29-2009 02:12 PM
Glass delamination GaiaOrion Boat Review and Purchase Forum 6 02-21-2009 05:13 PM
