speed on different tacks - SailNet Community
post #1 of 5 Old 07-22-2012 Thread Starter
I sail a Columboa 8.7 circa 1977. The boat sails faster on starboard tack than on port - 6 knots vs 4.5 - 5 knots. Boat weight is evenly distributed - mast is straight. Tension on shrouds is OK. I have not checked with GPS. Can this be a knotmeter/paddlewheel problem?
Clyde
ClydeEStarr is offline
post #2 of 5 Old 07-22-2012
Re: speed on different tacks
Clyde,
It absolutely could be.
Also look at trim placement, and rig tune. Side to side rig tension should be a little different due to small differences in rig geometry.
Greg
Stumble is offline
post #3 of 5 Old 07-22-2012
Send a message via Yahoo to dacap06
I'd borrow a hand held GPS and check your speed with that. Be sure either to check it during slackwater time or else account for the current speed when you measure speed over ground (SOG) with your GPS.
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
post #4 of 5 Old 07-23-2012
marcusc130's Avatar
If the paddle wheel isn't mounted midline, or if it's getting some turbulence from the keel or rudder, that could cause a problem. Is the problem consistent? Many times I notice a faster tack when I'm sailing, due to current or prevailing winds.
marcusc130 is offline
post #5 of 5 Old 07-24-2012
grumpy old man
I agree with Marcus. If your speedo is off to one side it is getting different flows off the keel and that could account for the different reading.
Bob's Blog ....
bobperry is offline
Starboard and Port tacks? ImASonOfaSailor General Discussion (sailing related) 74 07-30-2012 08:58 PM
VMG with lots of tacks Barquito Racing 9 07-20-2012 02:01 PM
