help me i.d. this saucy SV? pics inside - SailNet Community
post #1 of 15 Old 07-22-2012 Thread Starter
dan catalyst's Avatar
can anyone help me id this tub? im thinking about buying her, on the cheap. the guy i talked to on the phone asked his wife who yelled out 'its a schock', im thinking no, but she still looks a little saucy.owner said it was a 27' in the ad and 28' or 29' on the phone. the companionway hatch is to starboard of center and owner states shes(the boat) is aprox 20 years old .thanks for your help guys!
Lindenberg 22 proto
dan catalyst is offline
post #2 of 15 Old 07-22-2012
SchockT's Avatar
Re: help me i.d. this saucy SV? pics inside
It doesn't look like any Schock I have seen, but they have produced quite a few different models over the years.
What's the length? Any other pics?
Looks like a bit of a project, but it could be a cool boat!
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #3 of 15 Old 07-22-2012 Thread Starter
added length and age to above, also transom is closed,flat and vertical, not c&c style raked forward or open like a modern racer.
Lindenberg 22 proto
post #4 of 15 Old 07-23-2012
minnow1193's Avatar
Dan, where are you located? I think i've seen that boat on the Craigs list here in tampa.
minnow1193 is offline
post #5 of 15 Old 07-23-2012
If it is a 20 year old WD Schock built boat the HIN will start with WDS...
You can also go to our website WDSchock.com and surf through the history section.
WDS123 is offline
post #6 of 15 Old 07-23-2012
SchockT's Avatar
Yeah I didn't see anything on the Schock Site that looks like it.
I thought you worked for WD Schock WDS123...you should be able to tell us!
Hull#101
SchockT is offline
post #7 of 15 Old 07-23-2012 Thread Starter
thank you wds!! dang minnow, now if it is a schock then everyone will know where to buy it out from under me,lol. yeah its near tampa,just south. if wd schock had anything at all to do with this boat or we decode her and find she has a sub 185ish phrf rating and a shower, then ill go take a look with some money in my pocket. i bet moniez that wd schock had nothng to do with this one, based soley on the flat,vertical transom
Lindenberg 22 proto
post #8 of 15 Old 07-23-2012
Go take a look at the transom and pull the HIN. even if it's not a Schock a quick google search will tell you manufacturer, and model in about 20 seconds.
Greg
Stumble is offline
post #9 of 15 Old 07-23-2012
Looks similar to the Yamaha 28 but tough to tell with the blacked out cabin sides.
SJ34 is offline
post #10 of 15 Old 07-23-2012
KIVALO's Avatar
Dock
I have no idea what it is but I bet all cleaned up that will be a sharp boat.
s/v KIVALO
2003 Hunter 260
"Any damn fool can navigate the world sober. It takes a really good sailor to do it drunk." - Sir Francis Chichester while loading his boat with gin.
WORK IS OVER-RATED
KIVALO is offline
Antifouling for the inside?!? patrickbwells Gear & Maintenance 3 08-13-2007 12:35 PM
Antifouling for the inside?!? patrickbwells Gear & Maintenance 4 08-13-2007 01:41 AM
Inside Passage WarmCozyBoat Chartering 0 05-24-2005 10:54 AM
BC Inside passage arman Cruising & Liveaboard Forum 7 07-10-2004 05:49 AM
Chainplate - inside or outside? kmeeks Gear & Maintenance 2 04-15-2003 10:52 PM
