rudder replace - Page 2 - SailNet Community
post #11 of 15 Old 07-25-2012
Senior Cruiser
sea_hunter's Avatar
Originally Posted by c'm again:901099
is the fiberglass the key to strength and durability?
I prefer epoxy as it's water proof (that's why its used over fiberglass as a barrier coat) and yes the cloth and epoxy are combined to give the rudder overall strength. You still should have metal stringers attached to the rudder stock for mechanical strength through to the tiller or wheel.
sea_hunter is offline
post #12 of 15 Old 07-26-2012
Bluenoser
jimjazzdad's Avatar
Re: rudder replace
I had good luck with Foss Foam when replacing the rudder on my 1983 Hunter 37 Cutter. They had the mold in stock and shipped the rudder a week later - very pleasant to deal with. I did coat the new rudder with epoxy barrier coat before applying the initial anti-fouling. 10 years later, that rudder is still going strong. I was using a stock design that they had made before - I can't offer an opinion on their custom work.
jimjazzdad is offline
post #13 of 15 Old 07-27-2012 Thread Starter
Re: rudder replace
well the project has begun, alot slower gowing than I'd hoped, runs to the hardware store and such. thank you all for your imput. X your fingers not the best at such projects.
c'm again is offline
post #14 of 15 Old 07-27-2012
Senior Cruiser
sea_hunter's Avatar
So how are you building your new rudder? Any metal work need to be done?
post #15 of 15 Old 08-08-2012 Thread Starter
Re: rudder replace
using the hardware from old rudder, plywood coverd with fiberglass for the first one, now starting the second one, learning from my mistakes.
Gibsea 43' Rudder Rebuild/Replace Help jkemp Gear & Maintenance 4 11-02-2012 05:45 AM
Rudder cap stuck on rudder, how to remove? Capt. Mhack Gear & Maintenance 1 11-30-2011 11:55 AM
Can U Replace - Yanmar 1 Cyl With 2 Cyl. ?!? conquistatadore Diesel 12 11-16-2009 06:35 PM
replace halyard dogmandave Gear & Maintenance 52 03-07-2007 05:42 PM
How to remove and replace rudder Catalina 30 justtls06 Gear & Maintenance 1 07-01-2006 09:58 AM
