Off to Indonesia - Page 2 - SailNet Community
 5Likes
post #11 of 17 Old 07-30-2012
Once known as Hartley18
Classic30's Avatar
Dock
Re: Off to Indonesia
Originally Posted by killarney_sailor View Post
Actually we are going to South Africa to avoid the pirate waters further north. The advice from the naval forces patrolling the area is to stay south of 12°S when west of 78°E. We will stop at Christmas, Cocos-Keeling, Mauritius, Nossy Be in Madagascar, and then reach South Africa at Richards Bay in mid November - we hope.
Good-o... Of course you could always drop by Perth (Ilenart, et al) for a bit if you wanted a touch of civilisation mid-journey. You'll enjoy Cocos!
We have moved out of the marina where we have been for two weeks and are now anchored at Fanny Bay along with about 90 other boats. There was a nice breeze this afternoon (sea breeze?) but nothing before or after.
..and here I thought you'd left already.
Anyways.. have a wonderful voyage!
Classic30 is offline
post #12 of 17 Old 08-05-2012 Thread Starter
Bristol 45.5 - AiniA
Thought I had replied to this but it did not get posted it appears. We are now in Alor, Indonesia after two passages. First one to Kupang (think end of Bligh's famous small boat journey) was 470 miles and took 3 days and 4 hours - all downwind after the first 12 hours or so. Could not have been more relaxing or easier. The second one to Alor was about 135 miles and 31 hours which does not sound too bad but it was all a bit of PITA with the wind and currents shifting pretty much all the time. To top it off we had an impeller failure about 7 miles from the anchorage. There was about 4 knots of wind and we had about 2 knots of tidal current but that was going to change when the tide shifted within the next hour or so (if the tidal station was accurate). Also the engine was hot and changing an impeller on a Westerbeke 55 is not as easy as it might be (damned fiddly actually). Anyway we got a tow from a French boat that was passing - an advantage of a rally in a restricted area like this and got the impeller changed once anchored. It was an odd failure. All of the rubber vanes on the impeller were fine but the rubber part had separated from the metal sleeve inside so it was a catastrophic failure - went from working to not at one time. Not had that experience before.
One thing about cruising (or travelling) in a Moslem country, although this part of Indonesia has a large Christian population, is having the call to prayers 5 times each day (earliest is around 4 am). I don't know if they are recorded or someone is actually doing the chants live, but in Kupang they were very pleasant and relaxing. The person doing them had a very nice tenor voice. Last night in Alor there were three of them going (3 mosques) and they were quite unpleasant. Poor PA systems jacked up too high and the voices were not very good and the interactions nasty.
Finishing our major refit. Our trip to Newfoundland is off because it is too late. Hoping to go to the North Channel instead.
killarney_sailor is offline
post #13 of 17 Old 08-05-2012
tdw
Super Fuzzy Moderator
tdw's Avatar
Bruce, Good to see you made it through OK other than the impellor. I've had one impellor go as you've described but funnily enough it only fell apart as I was taking it out for routine replacement.
btw ... do you have one of these ? If not you should though I dare say finding one in Indonesia may not be all that easy. From memory we got ours from the UK.
Welcome to Speedseal Safety Covers
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #14 of 17 Old 08-05-2012
St Anna's Avatar
Bruce, if you need something, email!
I havent asked him, but am pretty sure that between Andrew and I, one of us should be able to source it and post it over.
St Anna is offline
post #15 of 17 Old 08-06-2012
tdw
tdw's Avatar
No need to ask. I'm buzzing off to the Syd Boat Show this afternoon, so I'll see if they have an Oz stockist yet.
― Terry Pratchett.
tdw is offline
post #16 of 17 Old 08-06-2012 Thread Starter
Thanks for the offers of help. The problem would not be helped by one of those quick on/off covers. The pump and impeller are just positioned in such a way that you cannot get at the half of the cover - nor have room to get out the impeller without taking off the drive belt and turning the water pump a bit. It is sort of like the impeller housing was positioned and then they decided to add some more goodies (like engine mount) to the gear.
post #17 of 17 Old 08-06-2012
tdw
tdw's Avatar
Well that is a bummer. Yanmar on the other hand seem to design the placement of their water pumps around the arm length of an Orang-utang. It is mind boggling really. The two most likely things to go wrong on a diesel would be the impellor and/or the fuel system yet do they put those items close to hand ? Don't be silly, of course they don't.
ps - no Oz distributor for Speedseal it seems. Have to order direct from the UK.
― Terry Pratchett.
tdw is offline
Indonesia cruising darryn900223 General Discussion (sailing related) 4 07-23-2012 04:11 AM
Crewing wanted between Indonesia to Australia danjoens Crew Wanted/Available 0 05-15-2010 04:31 AM
Crew avail. Australia -> Indonesia/Asia bengold Crew Wanted/Available 1 08-04-2009 05:36 AM
Indonesia -> Australia pesef Crew Wanted/Available 0 01-23-2004 10:48 PM
Sailboat Wanted Indonesia Ersmajones Crew Wanted/Available 2 02-26-2002 06:39 AM
