Beach Cats in Rehab! - Page 4 - SailNet Community
 21Likes
post #31 of 98 Old 08-10-2012 Thread Starter
Re: Beach Cats in Rehab!
Originally Posted by oysterman23 View Post
Gee Smack. Can you do that while slowly rising in a bosun's chair. (Force 5....42' max) ?
No problem.
smackdaddy is offline
post #32 of 98 Old 08-11-2012
Tartan 27' owner
CalebD's Avatar
Nice work Smachster chronicling your work on this Spirit 17".
I hope you and your boys get to sail the 'heck' out of that beach cat when you're done.
Have fun, be safe.
Caleb
Everybody has one:
CalebD is offline
post #33 of 98 Old 08-11-2012 Thread Starter
Thanks Caleb.
post #34 of 98 Old 09-02-2012 Thread Starter
I know everyone has been waiting breathlessly for the next installment of "De-Skanking Lilo". So here we go...
My plan was to gelcoat the hulls using this stuff:
I'd seen this video showing application with a roller:
They said 3 coats would provide good coverage - and I LOVED the idea of it lasting for years with the ability to buff out scratches, dullness, etc.
The issue was the cost...$110 (with shipping) for 1 gallon. And though the specs said that gallon would cover both my hulls - it was possible that I'd have to get a second gallon since I think that's the only quantity they sell. $220 started sounding a bit scary. I also found a couple of horror stories online about guys that used the stuff with bad results - although it sounded like they had done a poor job of prep.
I had also been looking at, and talking to lots of people about, Brightside paint. I'd seen plenty of videos of people applying it with roll and tip - and getting crazy great results. But I'd also seen lots of people talking about how easily it scratches. The big plus was the cost/coverage versus the gelcoat above. I found a source online that sold it for $28/quart. The specs indicated that I could get away with 2, maybe 3 quarts.
Since my prime objective on this cat restore was to do everything as cheaply as possible, I decided to bite the bullet on doing extra maintenance (which I REALLY didn't want to do) and go for the less expensive paint option.
So, I took a print-out of the online price for yellow Brightside to West Marine - who price-matched it for $28/qt. (down from $45). Booyah!
First, I had one more soft-spot to repair. Did the old epoxy injection as shown.
It worked perfectly. Then it was a final sanding and cleaning to prep for the paint...
With the first hull up on the saw-horses, it was time to give it a shot. I used a Whizz roller and a foam "brush", rolling vertically, then brushing horizontally from the edge of the new paint backward. Paint straight out of the can.
I did it exactly like this guy is doing it:
Unlike his dark blue paint, however, I could immediately see that the yellow was not going to cover as quickly as I'd hoped...and I was nervous that the stripes would show through...
After the first coat, I lightly sanded with 320 paper, carefully cleaned the debris off, then laid on a second coat. Then I repeated all that for a third coat. Laying on the Brightstide was STUPID SIMPLE. Seriously, the stuff lays down like you wouldn't believe. It's pretty hard to screw up.
Granted, it's not "perfect" - but I was pretty amazed at the smooth finish. And it looks wicked awesome from 10' away (which was my goal).
The problem with Brightside comes with the non-flat bits. I flipped the hull and started working on the top-deck. The roll and tip went great until I hit the pylon. Trying to roll that thing, then smooth it with the foam brush was a nightmare.
With Brightside you really have to move pretty quickly. If you wait too long, you don't get the smooth flow from the new stuff into the stuff you laid down previously. It seemed I had about 3 minutes or so from the old section to the new (I painted in sections of about 18" from one end to the other). If I missed that window, the joint between the two sections wouldn't flow well, leaving some roughness. And you know when you're out of time when the foam brush starts squeaking. At that point, it's too late. So you have to just go from one end to the other in a single pop. You can't waste any time.
The pylons really slowed me down. So I came up with another plan...which also had it cons. I decided to pre-paint the other pylons...
The con with this is that joints between already dried paint, and new paint never smoothes out perfectly. But with the non-skid I was able to hide the problem pretty well...
The paint was so amazing that the original production flaws started showing up:
But I was pretty pleased with how it was turning out.
The problem was...I was using a hell of a lot of paint! 3 coats, and you could still just make out some darker areas...
By the time I finished this hull, I'd gone through 2 quarts - and just a tiny bit of the third. This was getting expensive. I was starting to wonder if the paint was the right call over the gelcoat. But it sure looked nice:
It took way longer than I thought it would. Was way too much sanding. Was way more expensive than I thought it would be (I ended up going through just over a gallon of paint) - but Lilo is starting to shine baby!
So it was time to put her back together. I re-assembled the tramp frame and had my boys lace it up.
It was at this point that I realized we had brought this skanky thing a LONG ways back...
From here...
To here...
We raised the mast, rigged everything, and hoisted the original, tattered sails for the glory shot...
We give you the 1975 Spirit 17!
Next is finishing up the rudders and tiller extension. Then it's off to the lake.
We're about to have some fun!
post #35 of 98 Old 09-03-2012
Tartan 27' owner
CalebD's Avatar
Nice job SmackDiddy. I like the yellow 'Banana Boat' look. Chicks dig that color too, or so I'm told.
The proof in the pudding will be after you let Lilo play beach cat for a year or so and see how the Brightsides holds up to a little beach dragging and abuse beach cats get. I'd guess that a 2 part LPU paint or gel coat might wear better than Brightsides but at some point you just have to make an executive decision and just run with it.
Looking good!
Everybody has one:
CalebD is offline
post #36 of 98 Old 09-03-2012
Wow...Looking good!
ParadiseParrot is offline
post #37 of 98 Old 09-03-2012
Senior Moment Member
SloopJonB's Avatar
Came out very nice. Should provide lots of fun for little $.
If I read it correctly, the new yellow paint ended up costing MORE than the gelcoat would have - any regrets?
SloopJonB is offline
post #38 of 98 Old 09-03-2012 Thread Starter
Thanks sloop.
You're right about the cost. The gelcoat was $110. I ended up spending roughly $175 on 5 quarts of paint (using 4.25 quarts).
My hunch is that rolling the gelcoat wouldn't have given me as nice a finish as rolling the paint. So I'm happy with that finish. It rocks. But, I'll definitely have regrets if this paint lasts less than 5 years.
post #39 of 98 Old 09-05-2012
That is some great learning for when you take on restoration of your next GOB. Or, better yet, MY GOB. Mine is really dingy looking with its 35 year old gel coat and would really appreciate your looking after it.
ccriders is offline
post #40 of 98 Old 09-05-2012
Just really impressive!
I need to show this to a friend of mine is currently fixing up a SOL CAT 18.
Not doing quite as thorough a job, but close.
Randy Browning
Norwalk, CT USA
sonosail is offline
1986 Catalina Galley Rehab dRabbit SailNet FAQ 6 10-29-2011 09:57 AM
Reading Light Rehab RainDog Pacific Seacraft 6 12-10-2010 07:27 PM
Hobie Cats Club (all Cats welcome) Mauryd General Discussion (sailing related) 28 03-30-2010 09:50 PM
a4--starting the rehab QuickMick Atomic 4 3 11-08-2009 04:02 PM
CS 33 #1 Head Sail Rehab for Furler Roberthorr CS Yachts 4 11-30-2008 09:31 PM
