How do you measure the waterline - SailNet Community
post #1 of 13 Old 07-26-2012 Thread Starter
How do you measure the waterline on a sailboat? I want to calculate the approximate best speed of my sailboat.
Do I measure the curve of the boat or just a straight line from the bow to the stern on the waterline?
boatingcruising is offline
post #2 of 13 Old 07-26-2012
Tim R.'s Avatar
Re: How do you measure the waterline
Unless this is a custom one-off build you should be able to find the LWL easily online. What kind of boat specifically?
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #3 of 13 Old 07-26-2012 Thread Starter
Hello Tim,
it is a Hunter 29' I am not sure of the model name
Domenic
post #4 of 13 Old 07-26-2012
Go to sailboatdata.com.
Theres a Hunter 290 listed with a 26.92 waterline.
One foot one way or the other is maybe one tenth of a knot so unless you are into serious racing, it really doesn't matter much.
Catalina 34
chuck53 is offline
post #5 of 13 Old 07-26-2012
Senior Cruiser
sea_hunter's Avatar
Straight line through center at water line, overall inside toe rail bow to inside toe rail stern through center.
sea_hunter is offline
post #6 of 13 Old 07-26-2012 Thread Starter
Tks everyone
My goal is to simply have some idea of what the optimum performance of the sailboat would be so I can have a goal to shoot for. I am not into racing, at least not yet!
so if the waterline is 26.92 than the sq root is about 5.18 ( i used the calculator) so the optimum speed should be about 6.95 say 7kn. I hope I can learn to get at least 5.5 - 6 out of the boat.
post #7 of 13 Old 07-26-2012
If you ever get to hull speed , please tell us the conditions
WDS123 is offline
post #8 of 13 Old 07-26-2012 Thread Starter
I am new to sailing but based on conversations with other sailors I get the feeling that reaching optimum hull speed is like getting the advertised gas millage in your car or obtaining the published speed of small aircraft at a set RPMs.
FORMUL: Optimum Hull Speed = Incredible Accomplishment
post #9 of 13 Old 07-27-2012
rbrasi's Avatar
So, if at 25' LWL, my hull speed calculates to 6.7 Kt. What is the best measure? I currently use a Garmin GPS to get my speed readings, but that is speed over land. How does that translate? I routinely exceed 6.7 with current and a decent wind, according to my Garmin.
1968 Cal 2-30
Sandpiper 2
MDR
rbrasi is online now
post #10 of 13 Old 07-27-2012
Doesn't sail enough
zedboy's Avatar
Apples to oranges - hull speed is an approximation of how a displacement hull will move. In flat water it shouldn't be hard to reach (I can even get close in my boat, which has horrific hydrodynamics - motor in well below w/l, ballast bolted to side of keel...
What builders/designers advertise is not hull speed, but polars - which ought to be based on their real world measurements (tho designers may post calculated polars on a design before it's built)
Ability to maintain hull soeed in varying conditions and over a sustained period of time is much trickier than hitting it for a few minutes 135 off the wind on a nice day
zedboy is offline
Tags
speed , waterline
Looking for C&C24 in Georgia to measure Madhatter23ct C & C 0 07-06-2012 09:45 PM
measure amp usage QuickMick Electrical Systems 17 03-31-2010 08:24 AM
how to measure sails pyrateparrothead General Discussion (sailing related) 7 02-22-2009 09:50 AM
How do I measure for shaft length? dhornsey Gear & Maintenance 3 06-20-2008 07:24 AM
Where to measure a winch at? wildcard Gear & Maintenance 9 07-16-2007 09:04 AM
