Resealing and rebedding cabin windows/ports with Butyl tape - Page 2 - SailNet Community
 10Likes
post #11 of 15 Old 07-31-2012
Courtney the Dancer
jrd22's Avatar
Re: Resealing and rebedding cabin windows/ports with Butyl tape
Understood Chris, I use butyl for all my deck hardware but making a water tight seal on glass is extremely difficult, especially since the different materials expand and contract at different rates. I'm just saying that between the frame and the glazing there isn't generally a great deal of compressive force and I'm not sure using butyl is the best material for this application. I may be wrong, maybe Mainesail, who got us all started using butyl, will chime in here with his experience. Re-sealing ports is a time consuming job, not something you want to have to do more than once.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #12 of 15 Old 07-31-2012
You really are funny!!
chrisncate's Avatar
Good point, mine were all through bolted and I could adjust/apply pressure fairly precisely - not all (not most prolly) ports are like that. Still though, it'd be a tough call as even when butyl does develop a leak, it's so much easier to repair. Any curing goops would necessitate a total removal of all the old material, new surface prep and a full re install whereas butyl can be fudged with with a heat gun and some manipulation right in the trouble spot.
I don't know what would actually be best for a light pressure application like some ports would apparently be. Tough call I guess.
Mine (well, some other guys now..)
WildJasmine likes this.
chrisncate is offline
post #13 of 15 Old 07-31-2012 Thread Starter
Butyl is used by many auto manufacturers to seal windshields. It is laid down, the windshield is placed on top then a secondary seal typically made of rubber and metal is fastened into place using mechanical fasteners or adhesives.
Butyl seals glass with no issues as long as there is pressure applied which is why I used it. When I originally looked into using it I contacted a glass shop who told me that they use it to bed glass into aluminum window frames. my frames are aluminum. Trust me when it was not easy to squeeze those 2 pieces of frame together and the pressure is held by the four screws holding the frame together.
Hopefully this addresses your concern.
jason357 likes this.
Never sailed before. Quit my job, bought a SMALL sailboat and moved on with the wife dog and cat. Blogging about our experience Thewildjasmine.com
WildJasmine is offline
post #14 of 15 Old 07-31-2012
Maine Sail's Avatar
Only in recent years has the auto industry moved away from installing windshields with butyl ribbon tape. It worked for 50+ years on car glass bumping up and down the roads of the world....
______
-Maine Sail / CS-36T
Maine Sail is offline
post #15 of 15 Old 08-01-2012
Courtney the Dancer
jrd22's Avatar
Butyl it is from now on for all ports and windows!
John
SV Laurie Anne
jrd22 is offline
Resealing/Replacing Beckson Ports? HBBurlington CS Yachts 14 04-05-2012 04:16 PM
Re-bedding Windows: 3M-4200 v. Butyl Tape saildork Gear & Maintenance 16 04-13-2011 02:08 PM
Resealing Windows ccriders Gear & Maintenance 2 12-05-2010 10:12 AM
Catalina Owners - Butyl Tape for "New" Style Windows? cas8100 Gear & Maintenance 1 06-22-2009 08:58 PM
Rebedding toerail...butyl tape mess Finallybuyingaboat Gear & Maintenance 8 03-30-2009 01:36 PM
