Lazy head sail sheet snag - SailNet Community
post #1 of 3 Old 07-30-2012 Thread Starter
SV Skalliwag #141
brokesailor's Avatar
I installed a life raft on a cradlefoward of the mast. Now when I tack the headsail the lazy sheet will snag under the craddle if I don't preposition it above the liferaft prior to the tack (which a lot of times I forget till it's too late) Anyone have similar issues/solution? Disregard tape job.
brokesailor is offline
post #2 of 3 Old 07-30-2012
Re: Lazy head sail sheet snag
I would try attaching one or two bungees laterally, across the raft container, from one grab rail to the other. They might prevent the sheet from snagging on the bottom of the cradle, guiding the sheet up and over the container as you tack.
Sailormon6 is offline
post #3 of 3 Old 07-30-2012
Courtney the Dancer
jrd22's Avatar
Hard to tell how much space there is between the mast and the raft, but if you could either tie a line(s) or use bungees from the mast to the forward part of the raft (around the back of the mast and over the top of the raft at the two front corners) that would help to keep the sheet from getting behind it. Amazing how the sheets will find anything and everything to get snagged on.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
Smooth-Sailing Corporates Hit Snag, Still Resilient NewsReader News Feeds 0 01-31-2012 12:50 AM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
C-270 Main Sail zippered cover w/ lazy jacks, "Lazy Bag", "Quick Cover" Installation randy22556 Gear & Maintenance 0 02-27-2007 05:02 PM
Sailing: Major snag for Knox-Johnston (Guardian Unlimited) NewsReader News Feeds 0 01-13-2007 10:15 PM
Head sail furling obiec Gear & Maintenance 2 02-18-2003 05:54 AM
