The Infamous Leeward Shrouds - SailNet Community
 27Likes
post #1 of 49 Old 07-31-2012 Thread Starter
1979 C&C 30 MK1
flyingjib's Avatar
Hello Gurus,
I was out sailing the other day and I noticed my leeward shrouds were pretty much flopping around all over the place. We had 15 knots of wind going at the time and she was healing pretty good. I tried to tension them at the dock using my loos gauge. I brought them up to 13% of breaking strength but when I went out again they were still flopping around. I know this subject has come up again and again but here is my delima:
I have a 33 year old C&C 30 MK1 which I adore. Should I really bother with tightening them up more while tacking? Considering I'm at 13% right now, I imagine I would have to bring the tension to near 20% to make the flopping stop. She is been a great boat to me and I just feel like that's way too much stress on the hull, rigging, and everything else. I'm not a racer and I don't mind not having a finely tuned rig. Can I just use a bungee cord to reduce the shock loading the way I have seen done by some cat folks? Do you consider this a major safety concern requiring immediate attention?
Any advise is greatly appreciated.
Aaron
*** Update *** 08/06/2012
(Video was taken on a 15+ knots wind with gusts up to 25+)
flyingjib is offline
post #2 of 49 Old 07-31-2012
Re: The Infamous Leeward Shrouds
Rig tune has nothing to do with the leeward shrouds, unless you have diamond stays or jumpers.
Let them flop, just secure the cotter pins.
Greg
Stumble is offline
post #3 of 49 Old 07-31-2012
Did you ever see a dog take off running at full speed until he got to the end of his leash, and it jerked him off his feet to a sudden stop? Overly loose shrouds are like that leash, that is just long enough to let the dog get to full speed before it jerks him up short. I have sailed on boats that had shrouds so loose that the whole rig banged loudly in a chop, as the rig slammed back and forth. That's hard on the cables and hard on the connections.
I don't use a Loos gauge to tension my stays. For general daysailing and cruising, I want the mast erect and in column, and raked aft just enough to produce a light but adequate weather helm. When the mast is oriented approximately correctly in those respects, I snug each of the stays and shrouds, alternatively, and by an equal number of turns, just enough to take the slack out of them. Then I sail the boat in 10-15 kt winds, and watch the shrouds and stays. If the leeward cables go slack enough to "sway in the breeze," I tighten them alternatively and by an equal number of turns, until the leeward cables just relax in 10-15 kt winds, but don't sway loosely. In short, I want them just taut enough to hold the mast erect and in column and to restrain the mast from moving about excessively, and no more.
Tuning a sailboat rig isn't like tuning a guitar, where you want each string to vibrate at a specific frequency, to produce a specific sound, and that's why I see no need to use a Loos gauge. Your objective is simply to hold the rig erect and in column, which maximizes it's strength, to prevent it from moving excessively in a seaway, and to provide a proper support for your sails. If you adjust the cables with just enough tension (and no more) to accomplish those objectives, then the cables won't be so taut as to overly stress the rigging and chainplates. A Loos gauge is just one way of approximating the correct amount of tension.
Of course you can fine tune the rig for racing, or for sailing in light air, etc, but this question is only about basic tensioning, and not sail shaping.
Sailormon6 is offline
post #4 of 49 Old 07-31-2012
Otter
DivingOtter's Avatar
I had the same problem. Shock loading for rigging is a bad game to play.
DivingOtter is offline
post #5 of 49 Old 07-31-2012
Chastened
Ajax_MD's Avatar
Does it do this equally on each tack?
Have someone drive, while you go on deck and sight up the mast. Is it straight and true, or is the tip falling off to leeward? If it is, you are at risk of a dismasting.
At the dock, take the jib halyard and take the shackle to a stanchion base on the port side. Now take it to the starboard side stanchion base. Does the halyard reach to the exact same point? If not, your rig is not symmetrical, and so it's not equally loaded.
From the photos I can see, you have a single lower shroud on each side, and a single upper shroud. This shouldn't be too difficult to tune.
flyingjib likes this.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is online now
post #6 of 49 Old 07-31-2012
HANUMAN
RobGallagher's Avatar
Originally Posted by flyingjib View Post
Hello Gurus,
Aaron
I used to own a 30MKI. The leeward shrouds are pretty loose when healed and beating in heavier air. Just be sure they are tuned properly on both tacks, check your tabs and chain plates as it's an older boat and you should be fine. It's never a bad idea to hire a rigger for an hour or so to inspect your rigging every few years.
The main on your boat is fairly small compared to more modern rigs. You have a very stout mast being held up by oversized wire on a well built boat. You are probably sailing with a large headsail so having some bend in the mast might help a bit.
RobGallagher is online now
post #7 of 49 Old 07-31-2012 Thread Starter
1979 C&C 30 MK1
flyingjib's Avatar
It does it pretty much equally on each tack.
Also, I have used a long tape measure which I pulled up with my Halyard and measured the distance to each chain plate. They are equal.
The mast does look straight and I haven't seen any noticeable bend.
I only have a single upper and lower shrouds. They're both 1/4" 1/19 wire.
post #8 of 49 Old 07-31-2012
Chastened
Ajax_MD's Avatar
Doesn't sound like there's a real problem here then. You were sailing in a decent breeze with a large headsail, so you got some slack in the lowers.
I notice you're in the Annapolis area. We'll have to link up sometime for a drink. There's a C&C 30 named "Yes" that sails in my river, and those guys really clean up in the Wednesday night races. Nice boat.
post #9 of 49 Old 07-31-2012 Thread Starter
1979 C&C 30 MK1
flyingjib's Avatar
It would be great to meet up for a drink. I keep my boat in Back Creek around Jabin's...
post #10 of 49 Old 07-31-2012 Thread Starter
1979 C&C 30 MK1
flyingjib's Avatar
Well... I was looking more carefully at the mast collar today and I noticed mast wedges are only placed in fore and aft of the mast. There are no wedges supporting the sides. Could lack of proper mast wedges cause some of the problem I'm having?
Tags
loose shrouds old boat
Loose leeward shrouds? Stearmandriver General Discussion (sailing related) 29 10-13-2011 07:18 PM
Why is the leeward boat stand on? davidpm General Discussion (sailing related) 13 07-15-2009 07:01 PM
Tightening leeward shrouds while sailing pomerantz Pacific Seacraft 12 01-05-2009 03:05 PM
Lugger Leeward 16.... windship Boat Review and Purchase Forum 5 09-05-2006 04:59 PM
rounding leeward jrwright General Discussion (sailing related) 1 05-23-2004 06:49 PM
