C&C30MK1 Sail identification - Page 2 - SailNet Community
post #11 of 16 Old 10-11-2013
Fortuitous
chip's Avatar
Re: C&C30MK1 Sail identification
You can calculate the exact sail size with a tape measure and some online calculators.
  • Measure all three sides of the sail.
  • Use Heron's formula to calculate the area.
  • Use the area of a triangle formula (area equals 1/2 base times height), with the area you just got from Heron's forumula and the luff as the base. Solve for height, which is your LP.
  • Divide your LP by your J and multiply by 100 for the sail size.
I think that works, anyway. I did it for my sail, which I got used, and it came out to a reasonable number: http://sailingfortuitous.com/new_plateau
My Boat Log, or "blog" if you will:
chip is online now
post #12 of 16 Old 10-11-2013
The easiest way to know exactly what the LP is:
With the sail on a relatively flat surface, measure the distance from the back corner (clew) to the shortest distance on the luff, (perpendicular to front edge). If you are using English units, divide by 13.5'. (J measurement for your boat). Then multiply by 100 for %.
The second sail you are showing is a polyester/mylar laminate of some kind which accounts for the different orientation of the seams. You probably won't want to have this sail up in strong winds.
rb
Randy Browning
Norwalk, CT USA
sonosail is offline
post #13 of 16 Old 10-11-2013
Fortuitous
chip's Avatar
Yeah, or that if you don't need 10 decimal places of precision.
chip is online now
post #14 of 16 Old 10-11-2013
Not sure what you mean.
But my post wasn't meant as a reply to, or criticism of yours.
It didn't even see it until after I had left my own.
rb
Randy Browning
Norwalk, CT USA
sonosail is offline
post #15 of 16 Old 10-11-2013
Fortuitous
chip's Avatar
Yeah, I'm saying your way is way easier.
chip is online now
post #16 of 16 Old 10-14-2013 Thread Starter
First String
Thanks guys
ltgoshen is offline
Battery identification Minnewaska Gear & Maintenance 49 04-10-2012 02:13 PM
C&C 30 head sail identification ltgoshen General Discussion (sailing related) 4 12-16-2011 11:50 AM
Identification please imiloa Sailboat Design and Construction 5 09-15-2008 05:13 PM
dinghy identification fishboyneil Sailboat Design and Construction 5 04-28-2008 09:24 AM
Boat Identification ryderwolf Boat Review and Purchase Forum 4 11-13-2006 07:54 PM
