Originally Posted by SlowButSteady
Butane can + pinhole leak + spark = KABOOOM!!!!
There's an app for that...
Get about 2' of 3" ID PVC Pipe, and two end caps, and 2 long zip-ties.
Glue one end cap on the PVC.
Drill 2 holes through the PVC end cap that you just glued to the pipe.
Put 1 zip tie through the two holes.
Connect the PVC pipe with cap to the bottom of the pushpit with 1 zip-tie. (leave the uncapped end facing up).
Use the other zip-tie to loosely hold the open end of the pipe to the top of the pushpit.
Drop the cans into the PVC pipe.
Cover with the remaining cap.
Tighten both zip-ties.
I did this with 4" PVC to hold the 1lb propane tanks that I use with my Magma
grill. Works like a champ!
