Mechanic near Stamford or Norwalk CT? - SailNet Community
 1Likes
  • 1 Post By jppp
post #1 of 6 Old 08-09-2012 Thread Starter
Hi, can anyone provide a referral for a good diesel mechanic around Stamford CT that would travel to my boat to do some engine work?
Thanks
shamrock6 is offline
post #2 of 6 Old 08-09-2012
jppp's Avatar
Re: Mechanic near Stamford or Norwalk CT?
I'm sure any marina can recommend someone if no one chimes in.
While in Rye on a mooring we avoided begging our diesel mechanic to make a trip to Rye from Croton-On-Hudson. He patiently talked us through Changing Filters, Emptying out our full diesel tank and replacing it with clean diesel, bleeding all the air out of the system from primary filter-lift pump-secondary filter-injection pump-injector. This took all of Monday and 14 launch trips to go get stuff. I no longer fear my 2QM15. I think I can do that changing filters/bleeding stuff now in 30 minutes.
What seems to be the trouble?
1985 C&C 35 MK 3
jppp is offline
post #3 of 6 Old 08-09-2012
Tartan 27' owner
CalebD's Avatar
Along the line of thought jp**3 started, if you get this book: http://www.amazon.com/Boatowners-Mechanical-Electrical-Manual-Essential/dp/007009618Xand you are not afraid of a socket wrench set you maybe able to save yourself some money and time.
Everybody has one:
CalebD is online now
post #4 of 6 Old 08-10-2012 Thread Starter
I can't seem to get fuel through the injector pump. I think I have exceeded 14 trips on the launch! This is my last step before spending the money on an injector pump.
post #5 of 6 Old 08-10-2012
jppp's Avatar
You cracked open the fuel line coming out of the injector pump and either primed manually or cranked the engine? After 8 hours this is where we were. Solution was to bleed air by opening fuel line leading from secondary fuel filter into injection pump. The second we saw fuel she fired up.
I just ordered the book above. Thanks,
jp
CalebD likes this.
1985 C&C 35 MK 3
jppp is offline
post #6 of 6 Old 08-11-2012
Tartan 27' owner
CalebD's Avatar
Shamrock6,
As jppp suggests, you might need to try bleeding the fuel lines of air. You don't know if you might need a new lift pump (from the tank) or injector pump (high pressure). Filters need to be changed regularly but I'm sure you've done that by now.
The book I linked to actually covers this for most diesel engines, and other usual maintenance stuff. I've never been sorry that I bought it even though I have a gas engine (Atomic 4).
Everybody has one:
Norwalk CT BarryL Long Island 11 08-20-2015 11:32 AM
Anchoring off Norwalk Islands, CT? tmalcolm General Discussion (sailing related) 2 08-16-2010 05:48 PM
Norwalk Ct Boat show brigadoonboat Boat Review and Purchase Forum 1 09-29-2009 05:30 PM
Ideas for a 4 week itinerary norwalk to boston lewielewie42 Cruising & Liveaboard Forum 13 03-16-2009 10:21 PM
