solar help - SailNet Community
post #1 of 8 Old 08-15-2012 Thread Starter
Huck
smallboatlover's Avatar
solar help
my panel read 3.5-4 volt but only .1 amps is it charging or is it junk?
16' mistral sailboat, And 27' coronado
smallboatlover is offline
post #2 of 8 Old 08-15-2012
Re: solar help
kindof sounds like junk
sawingknots is offline
post #3 of 8 Old 08-15-2012 Thread Starter
Huck
Re: solar help
ok thanks
post #4 of 8 Old 08-15-2012
Re: solar help
What kind of panel?
Under what conditions?
and how are you measuring the amperage? under load? shorted?
The voltage sounds awfully low for an open circuit voltage for pretty much any panel you'd buy so either the panel is junk, or more likely, you might be reading it wrong.
~Fortunat
fmueller is offline
post #5 of 8 Old 08-15-2012
Cruiser2B's Avatar
Re: solar help
before totally writing off the panel as junk, check all the connections for corrosion. And i know this may seem stupid and obvious but you did check output in direct sunlight?....had to ask
My two lovely ladies!!
USCG 100T Near Coast Master with 100T Inland Sail Endorsement
Cruiser2B is offline
post #6 of 8 Old 08-15-2012 Thread Starter
Huck
Re: solar help
yes i was holding it in direct sunlight
post #7 of 8 Old 08-16-2012
Large Member
Re: solar help
Was the panel disconnected from your charging system?
mdbee is offline
post #8 of 8 Old 08-16-2012
Re: solar help
What kind of panel?
wnvvea is offline
Solar deck instead of solar panels ulferlingsson Gear & Maintenance 34 01-31-2013 06:03 AM
Anyone bought solar panels from Sun Solar? justonemoreproject Electrical Systems 1 04-18-2012 06:08 PM
Solar fans JLBJR Gear & Maintenance 22 01-27-2009 10:42 AM
Solar Stik Freesail99 Gear & Maintenance 21 10-24-2007 06:12 PM
think they use solar ? sailusvi General Discussion (sailing related) 0 10-08-2007 09:12 PM
