Alburg 30 questions - Page 2 - SailNet Community
 1Likes
post #11 of 25 Old 08-15-2012
You really are funny!!
chrisncate's Avatar
Re: Alburg 30 questions
Hey, that's the same one you rejected before..
Getting desperate?
That boat is doable, but you gotta get your head around the work involved. It's going to take a lot, but if you're determined you CAN make it happen.
It's a lot of work though...
chrisncate is offline
post #12 of 25 Old 08-15-2012
Chris, you mean the ones the chainplates are attached to?
How do you extend them reasonably, I thought most of the load was on the ones on the main bulkhead, I'm in the middle of glasswork in my V-beth, and going to have the whole area insulated after so I'd rather sort any details like that now.
To the OP, looks like a solid boat in need of a bit of work, like my A30. Good to see someone did the mast support beam repair already.
Jgbrown is offline
post #13 of 25 Old 08-15-2012
Cruiser2B's Avatar
Originally Posted by chrisncate View Post
Gotta disagree on the chainplate/chainplate bolts - they do appear original, there are only three @ 5/16th or even 1/4" maybe, and they are undersized. They will need replacing as will the chainplates in all likelihood.
FWIW, My (ex) A-30 did not look like that at the hull to deck as viewed from the inside. Mine was sealed solid with heavy roving that appeared to be factory. I had an early hull# though, and that might make a difference. I'd glass up what you see there on that boat for a nice clean finish and added strength.
I usually dont disagree with you and maybe they are stock but heres a pic of mine which were machine bolts with rounded sloted heads, the ones in pic have a hex head and appear to be 5/16 or 3/8. According to the Alberg site 1/4 machine screws were used and upgrading to 5/16 is sufficient. It wasn't for me as I used 7/16. I do agree that either way being that they are painted they should be removed and inspected along with chainplates.
My two lovely ladies!!
USCG 100T Near Coast Master with 100T Inland Sail Endorsement
Cruiser2B is offline
post #14 of 25 Old 08-15-2012 Thread Starter
champlain94's Avatar
Alburg 30 questions
No this is not the one I rejected before. This one is a different one. Here is an older survey on the boat. He is asking $10,000
THIS OLD BOAT
champlain94 is offline
post #15 of 25 Old 08-15-2012
chrisncate's Avatar
The proper way to extend them would be vertically. You knock the old brown mushy ones completely off, fair out the area then install your newly built longer laminated ones that are covered in many layers of glass and epoxy, tabbing them to the hull with glass roving and epoxy. The new ones would go lower than the shelf right underneath them.
Another way (what I did) is if yours aren't mush inside (take a core sample), you can just add heavy glass and epoxy over the original tabbing, extended farther aft and forward than the original tabbing. Basically, just build the area up with more glass and epoxy.
You're right in that they aren't as load bearing as the ones on the main bulkhead, however they are they ones that are known to rip out. It's how Yves Gelina lost his mast - those were the failure point. The ones pictured here look pissweak to me, at least compared to the baseline I started with on my A 30.
Fwiw.
Jgbrown likes this.
post #16 of 25 Old 08-15-2012
chrisncate's Avatar
I have been seeing some tight boats out there for 10 to 15k, do you have any other candidates? Are you limited to a local selection or can you travel a few states away?
post #17 of 25 Old 08-15-2012 Thread Starter
Alburg 30 questions
I want to stay in the NC SC area. I will have to motor down the waterway with little experience. And around $10g is the max I want to initially spend. I know that's asking a lot but what I do have is time. I'm in no hurry. There are a lot of sailboats out there. It's a buyers market. But I have a lot to learn. That's why I'm here posting pics and asking. Here's a picture of the last A30 chainplates I looked at
THIS OLD BOAT
post #18 of 25 Old 08-15-2012
Cruiser2B's Avatar
Yep....thems is original.... the first pic you posted looked like hex heads...so i stand corrected, sorry CnC
post #19 of 25 Old 08-15-2012
chrisncate's Avatar
5/16th is too small imo. you don't want any movement, ever. Mine with hefty 5/8th bolts (3/4" heads on those suckers), the backing plates are G-10:
Old vs new cp's when I was making them:
post #20 of 25 Old 08-15-2012 Thread Starter
Alburg 30 questions
Yes the one I looked at today. I am pretty sure has newer bolts through the chainplates. I don't know if the chainplates are new but I am
Sure the bolts aren't original the round screw head bolts are from
A major fixer upper I looked at a couple weeks ago
THIS OLD BOAT
AIS-B questions jrd22 Electronics 15 05-08-2012 12:52 PM
New guy with a ton of questions TyroneMainsheet Introduce Yourself 3 06-20-2011 02:22 PM
Two questions castoff General Discussion (sailing related) 2 08-04-2008 04:40 PM
two questions kananumpua General Discussion (sailing related) 18 11-07-2007 03:26 PM
Many questions rlockard Living Aboard 9 10-14-2003 03:09 AM
