Atomic 4 Shakes the Boat - SailNet Community
 3Likes
post #1 of 18 Old 08-16-2012 Thread Starter
I purchased a Cat27 last summer and am hooked. She has an Atomic 4 that runs like a horse.
Last weekend as i was headed back into port (under power at top speed) the boat suddenly lost a lot of speed and the motor got loud, the boat also started to shake. I throttled back on the gas and ran it at almost idle; the shaking stopped and i made it back into port.
I had a mechanic inspect it and he found nothing noticeably wrong with it.
I took her out for a test run to see if the issue persists; it does, when in low speed it runs fine, as soon as i gas her up she starts to shake and although the motor speeds up, the boat itself does not.
Does this sound familiar to anyone?
Ringoparr is offline
post #2 of 18 Old 08-16-2012
Check for something fouling the prop.
KBuckley is offline
post #3 of 18 Old 08-16-2012
Does it shake when you Rev it in neutral?
Probably not.
Almost certain you have fouled shaft
Sic Semper Tyrannis is offline
post #4 of 18 Old 08-16-2012
1975 Newport 28
jaschrumpf's Avatar
Re: Atomic 4 Shakes the Boat
Atomic 4s are some notoriously smooth-running engines. If you're getting vibration on that scale it's something else than the engine.
S/V Free Spirit
Monrovia, MD
jaschrumpf is offline
post #5 of 18 Old 08-17-2012
Chastened
Ajax_MD's Avatar
+1 on the fouled prop or shaft. Also inspect engine mounts.
Fixed prop or folding?
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #6 of 18 Old 08-17-2012
Learning the HARD way...
eherlihy's Avatar
Prop, prop shaft (and cutlass bearing), engine mounts..
eherlihy is online now
post #7 of 18 Old 08-17-2012 Thread Starter
The mounts we're fine and no, there is no shaking while in neutral... It's surprising (or maybe not) that my mechanic didn't mention anything about the prop. I'm going to jump in the water this afternoon to take a peek, i'll post a follow up... thank god its a hot day; 91 degrees in Seattle.
post #8 of 18 Old 08-17-2012
Take a good sharp knife with you. Bet you need it!
Sent from my Kindle Fire
post #9 of 18 Old 08-17-2012
TQA
Bombay Explorer 44
TQA's Avatar
Bread knife works best IMHO.
TQA is offline
post #10 of 18 Old 08-18-2012
Senior Slacker
SlowButSteady's Avatar
When you say that the motor got loud, did it sound like the exhaust got louder or was it more of a thumping/vibration? If it's the former then there may well be something wrong with the engine itself. If the latter, like others have said, it's probably a fouled prop, bad motor mount, bad cutlass bearing, or some combination of those.
BTW, I would look for a new mechanic if I were you.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
Tags
atomic 4 , catalina 27 , shaking , speed
Wind Generator Shakes Boat DocBrauer Electrical Systems 13 09-14-2011 11:32 AM
How much for an Atomic 4? jarcher Atomic 4 20 07-14-2010 03:31 PM
cal 34 atomic 4 tygertyger Atomic 4 1 07-09-2006 09:44 AM
China Shakes World Economy, Rattling Boeing, VW, ThyssenKrupp (Bloomberg.com) NewsReader News Feeds 0 04-11-2006 10:15 PM
ode to the atomic 4 jwellsfamily4 Gear & Maintenance 1 08-04-2003 11:13 AM
