Wifi on board - Page 2 - SailNet Community
 1Likes
post #11 of 21 Old 08-20-2012
Zed
Re: Wifi on board
If you are worried about the 5Gb limit, you can always select a different plan. Verizon now has plans (shared data plans), that run from 4Gb to 20Gb.
Zed is offline
post #12 of 21 Old 08-20-2012 Thread Starter
melody1204's Avatar
Re: Wifi on board
That's great! I'll look into that. I thought 5GB was the max. Thanks, Zed!
Melody -
- CAL 35
For whatever we lose (like a you or a me)
it's always ourselves we find in the sea.
~ e.e cummings
melody1204 is offline
post #13 of 21 Old 08-20-2012
TakeFive's Avatar
Re: Wifi on board
Note the GSM hotspots would allow you to change SIM cards if you hit your 5GB limit. If you hit your limit one month, you could activate a new SIM card and pop that into your phone or hotspot and keep working. For instance, the T-mobile $30 plan that gives you 5GB per month does not shut you down when you hit your limit - it just throttles you back to 2G speed. So when you hit your limit you could load up a second $30 card and keep going at 4G speed.
Unless you do a lot of video streaming or send huge email attachments, it's actually difficult for one or two users to use more than 5GB a month. You should also turn off automatic Windows updates (or whatever other computer OS) and do the updates manually when you have free WiFi access.
melody1204 likes this.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
post #14 of 21 Old 08-20-2012
If you are worried abiut the limits of a data plan you can try what did. I have my hub from Tmobile they have Xgug at 4G and unlimited at 2 G granted it is slower but it does always slow you done. Have had friends playing online games via this for hours straight and no slow downs
Jeremy
Pearson 10m
jhgreen is offline
post #15 of 21 Old 08-20-2012
SeaQuinn's Avatar
Re: Wifi on board
Good to know! I too need to be able to work from my boat. What is the best setup to boost the free wifi signals that I can get at the marina? It seems that down below I sometimes get a much reduced signal.
SeaQuinn is offline
post #16 of 21 Old 08-20-2012
Re: Wifi on board
I have been using a Verizon PCMCIA card for almost ten years. I have enough speed to stream music and video with no problems anywhere in the US. I also have unlimited data, but from what I can gather that plan is no longer offered.
Vartok is offline
post #17 of 21 Old 08-20-2012
Best Looking MALE Mod
Cruisingdad's Avatar
Re: Wifi on board
I have been using the ATT wifi. It works awesome. 4glte really is (or seems to be) broadband speed and 46 is a bit slower than dsl but doeable.
Let me caution about Verizon as they may not have the same coverage in the keys as ATT. THat was why I did not go with them.
Brian
PS My cost is $50/month for 5 gig, plus $10 for every gig over.
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #18 of 21 Old 08-20-2012
Re: Wifi on board
BTW, here is my recent thread on this:
Wi-Fi
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
post #19 of 21 Old 08-20-2012
Re: Wifi on board
This is where I plan to buy mine (probably tomorrow)!!
Marine PC's & WiFi by IslandTime PC
ALso, regarding the use of the wifi booster, my experience is that most marinas have WIFI, but few of them are actually reacheable from your slip. I would love to think I could use this on the hook, but reality is that I would just like to be able to use the marinas (which I pay for) from my boat!!! I suspect you will have the same issue.
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
post #20 of 21 Old 08-20-2012
formerly posting as eryka
wingNwing's Avatar
Re: Wifi on board
??? We have an Alfa range extender from Amazon, $25. We can see our marina's wifi, and the neighboring marinas, and the ones across the creek. Was a bear to set up, but once done, it's be fabulous for the last couple of years, down the ICW & Bahamas.
Cinderella, CSY 33, Photo by Joe McCary
Regret for the things we did can be tempered by time; it is regret for the things we did not do that is inconsolable. - Sidney J. Harris
Shameless self-promotion - my blog for the Annapolis Capital newspaper:
still has some glitches to be worked out. Until then, I'm posting at:
and
! And a new project:
wingNwing is offline
Tags
wifi
Free WIFI in BVI 6string Chartering 18 05-19-2015 04:24 PM
WiFi brokesailor Gear & Maintenance 4 12-02-2011 10:39 AM
Wifi jrd22 Gear & Maintenance 42 06-17-2009 12:51 PM
WiFi firstafair General Discussion (sailing related) 4 11-17-2007 02:34 PM
Wifi mallo Gear & Maintenance 3 03-21-2007 10:09 AM
