Winter storage on Great Lakes - Page 2 - SailNet Community
post #11 of 12 Old 08-22-2012
Seņor Member
PorFin's Avatar
Re: Winter storage on Great Lakes
Tim,
Here's another idea to mull over.
You mentioned that the surveyor's readings of the rudder were "relatively moist."
Water intrusion into a rudder is common, and letting it freeze over the winter won't make it any better. As it happens, it's also one repair project that can wipe out a long time during the sailing season.
If you've got a heated garage or basement, you could probably tackle this one at home over the winter. Although I've not pulled a rudder on a Sabre 32, looking at hull pictures it would seem to be a relatively easy task. Getting it off the boat while it's in the slings of the Travel Lift is way easier that having to dig a trench (which is also common) after it's been parked.
Anyway, more food for thought.
PorFin is offline
post #12 of 12 Old 08-24-2012 Thread Starter
Sounds like a good plan PorFin. I'll ask yard to drop rudder when it's in the slings. They have more torque wrenches/sockets in case bolts are frozen. Maybe if rudder repair is done right, it's not something I'll need to do each year.
Tim
AT EASE, 1985 Sabre 32
Cleveland, Ohio
tpm1950 is offline
Available in the Great Lakes MadBassett Crew Wanted/Available 3 10-20-2015 06:54 PM
Waterspouts on the Great Lakes miketucker General Discussion (sailing related) 12 09-21-2011 08:35 PM
Great Lakes Naval Base Winter Storage Finny Lake Michigan 1 03-25-2009 11:33 PM
Great site for info on the Great Lakes scottbr Lake Huron 0 03-14-2009 07:07 PM
water storage vs. land storage during winter apkaplan General Discussion (sailing related) 1 10-24-2007 04:50 PM
