Winter under a tarp - Page 3 - SailNet Community
 4Likes
post #21 of 34 Old 08-30-2012
72 C&C Corvette
CorvetteGuy's Avatar
Wink Re: Winter under a tarp
I've used tarps for years with no mat up on the hard, I use 2*6 pressure treaded wood and wrap the sides around the tarp making a sadwich, this rests on the deck on either side of the cabin then lash it down from port toerail to the starbort one the tarp does not get shreaded and it holds the contour of the topside. Works quite well
CorvetteGuy is offline
post #22 of 34 Old 08-30-2012
The worst thing about shrink wrap is poor ventilation. Even open toe rails and vents don't seem to change the fact that it gets pretty warm and moist under the things. Canvas is the best way to go.
Our Fairclough custom cover pays for itself this year and is still in great shape. I just don't get shrink wrap at all.
Jeanneau 54DS
Minnewaska is offline
post #23 of 34 Old 08-30-2012
DrB
Never shrink wrapped
Tarped for the first 3 years of ownership. As others have said, the key is a good solid frame network and good tarps. Leasons learned:
  • High ridge line/pole to allow snow shed
  • Sufficient number of cross members to support the tarp so it does not sag and hold snow
  • Heavy duty tarps
  • Getting shrouds incorporated is key
  • Many smaller tarps are better than fewer larger tarps.
After three years of the tarp, and trying to get it installed in mid November, my wife demanded a better mousetrap and one that we could install in a few hours instead of a w/e. We bought a Fairclough cover for our boat and although $$, the time it saves and the quality and fit are amazing. We can unload our frame from the car, install it and the cover in about two hours. The most time consuming thing is getting the frame supports and slats up on the boat while it is in the stands on on the blocks. The frame takes about 1.5 h to assemble (with unloading from the car). 15 -20 minutes to install the actual cover pieces and 20 minutes to tighten and snug up. We get minimal water on the deck and the boat is well ventilated. The cover fits the boat like a glove. No flapping edges or sagging areas.
Each year I had to spend about $150 in tarp supplies as tarps ripped some, wood pieces split, etc. It also took at a good part of a day to assemble the frame as the support slats were all screwed in to the ridge pole. Then it was another few hours to put on the plastic tarps. If it was windy, it took a lot longer. I always was checking on the boat after a heavy snow as something always undone. Now install it and once in a while check on the boat if I am in the area.
The custom canvas cover - Some of the best money I have ever spent for the boat.
Minnewaska and Mobnets like this.
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
post #24 of 34 Old 08-30-2012
You really are funny!!
chrisncate's Avatar
A tarp is maintenance and checking all winter, with minimum visit frequency of a couple of weeks (a couple of weeks max, a weekly visit to futz with it is optimal). Shrink wrap is set it and forget it.
chrisncate is offline
post #25 of 34 Old 08-31-2012
WinterRiver's Avatar
Shrinkwrap doesn't have to be tossed each spring. I used the same shrinkwrap for 3 winters before switching to a hand-me-down canvas cover. I still have the shrinkwrap cover stored, just in case.
WinterRiver is offline
post #26 of 34 Old 08-31-2012
Do you mean on the Hylas 47 in your sig? That's an unimaginable amount of contorted shrink wrap to store.
If it is shrunk tightly, how do you get it 'unshrunk' to remove and then 'reshrunk' the following year?
Jeanneau 54DS
post #27 of 34 Old 08-31-2012
tommays's Avatar
The shrinkwarp guy comes to my house and does the boat for 300 dollars over my well designed frame
A faircloth or other real nice cover is gonna have to last 20 years
AS i have used canvas in the past on other boats it was always IMHP more of a PITA dealing with BIG snows as it was harder to slide it off the canvas and always involved me and a pushbroom keeping the snow load in control
My friends cover already had to be re-stitched by that big company as a PO left in on over one summer voiding the warranty
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #28 of 34 Old 08-31-2012
4KSB driver.
My 22 footer, I used a tarp. I built a make-shift frame, and it lasted the winter fine.
Bought my 25 footer, and the gentleman used an elaborate PVC pipe frame he built (I have all the pvc)... Honestly it worked fine, but the boat was full of pieces of tarp, and was harder to clean than my 22 footer.
I am fortunate, that I may have indoor storage this year for my boat... my opinion is the shrinkwrap is more a set it and forget it... Tarps work fine, but you cannot drape over stanchions, and you have to bring the tarp's angle up to slide the snow easily off. I think if you do the tarp, you should step the mast as well (if you can), and throw the boom on, bring the boom way up, and drape the tarp over that. It's you're best bet. Then if you can run ribs across the boom to deck it'll better support the tarp.
Just my worthless $0.02.
I hope I don't need to deal with that again this year, always was sad to see her under cover.
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is offline
post #29 of 34 Old 08-31-2012
I've used the same heavy duty canvas tarp over the boat for at least the past 15 years and it's done very well. The boat spends the entire winter in the Annapolis area in the water and the tarp is not even mounted on a hard frame. I do remove all sails and string a line from mast to backstay to form a frame and also add some lines from mast to boom gallows for additional support. The canvas is then put over this "frame" and the edges tied to the handrails along the cabin top. In those 15 or more years that setup remains sound during all sorts of weather and wind. It does not cover the entire boat, but will keep the snow off the cabin top and most of the cockpit and allows me to walk around the deck of the boat.
lancelot9898 is offline
post #30 of 34 Old 09-02-2012
Yes, I mean the Hylas 47. It is quite a bit of shrinkwrap (less than your 54 would use), but rolled and folded it all fits in my wagon.
Since I can't cover the painted topsides with shrinkwrap, I run it to the toerail, which makes it easier to remove and reinstall. I use pvc electrical conduit to create a reuseable arched frame. When I removed the shrinkwrap, I carefully sliced it to the stays and cut it into two pieces at the mast. It was basically lots of taping where it was cut. Each time I reused it I had to add a small bit of new shrinkwrap at the mast cut because I couldn't quite pull the two sections together. I didn't unshrink it (I don't think that's possible) and only needed to reshrink it where I didn't tape it tightly enough.
Really crazy is the fact that I did the original shrinkwrap myself with a home heat gun. With it going only to the toerail I could do all the work from the deck and shrink it from inside. Total cost the first time was about $200, after that about $30 for tape, and I still have a lot of shrinkwrap left.
Shrink wrap vs. Tarp labatt Gear & Maintenance 37 05-05-2011 08:19 PM
Tarp for storage: Light or Dark color? TakeFive General Discussion (sailing related) 19 11-28-2010 12:46 PM
ICW in Mid-Winter? mrybas Cruising & Liveaboard Forum 1 02-23-2010 12:02 AM
winter christinero Living Aboard 4 11-20-2004 01:52 PM
Aluminum gromets on tarp mikehoyt Gear & Maintenance 1 05-06-2002 10:03 AM
