Winter under a tarp - SailNet Community
 4Likes
post #1 of 34 Old 08-25-2012 Thread Starter
Winter under a tarp
Hey All,
I'm looking for opinions about wintering under a tarp rather than shrinkwrap. We are in Maine and it seems like atleast 90% of the sailboats I see are shrinkwrapped in the winter (and that is what we did last winter too).
But why is that? It seems like a lot of work and then an awful lot of waste to throw the plastic away each spring. It seems to me that a good big tarp would be cheaper and re-usable. so why not?
If I build a decent frame for the tarp and secure it well, what is the downside? Is it less weather proof? more prone to blowing away?
We'll be on the hard (it is Maine, after all) and I'll probably keep the boat in the yard so I'll be able to check on it every day or so.
Thanks for your thoughts.
~Fortunat
1969 30 ft Dufour Arpege
fmueller is online now
post #2 of 34 Old 08-25-2012
Re: Winter under a tarp
heya! I'm brand new here so I've no actual or practical advice on shrinkwrap vs tarp, BUT, I did come across this other topic about just such a question. hopefully something in there gives you the answers you desire.
Shrink wrap vs. Tarp
AmorylTheWanderer is offline
post #3 of 34 Old 08-25-2012
If you can check on it each day use the tarp. I believe the shrink wrap is so you can put it out of sight and out of mind but what would I know. I leave my boat in the water year round without a tarp even.
kd3pc and oysterman23 like this.
lapworth is offline
post #4 of 34 Old 08-25-2012
Tartan 27' owner
CalebD's Avatar
Had our boat shrink wrapped one winter. I wasn't all that happy about the waste of materials and I found that the shrink wrap held as much water inside the wrap as it kept on the outside. If the job of shrink wrapping is not done properly with adequate ventilation then your boat can become a mold palace.
I've used tarps ever since. Cheaper, reusable and much better ventilation. Gotta' check on it though.
Everybody has one:
CalebD is offline
post #5 of 34 Old 08-25-2012
I tarp over the boom only, to cover cockpit and companionway hatch, to top of stanchions. On hard or in water.
1970 Havsfidra 20 by Fisksatra
On the Delaware River at Fox Grove Marina Essington PA
Ulladh is offline
post #6 of 34 Old 08-25-2012
nauticalrich's Avatar
I don't tie my tarps to the stantions. I've seen a couple boats with bent stantions due to the weight of a tarp when water or snow puddles in it.
I use tarps and always check them.
nauticalrich
1985 31 Oday
Bridgeport, CT
nauticalrich is offline
post #7 of 34 Old 08-25-2012
It is a 20ft boat, not a lot of tarp to hold snow, if snow load is a concern tie to base of stanchions. The intent is to minimize snow in cockpit that may melt and re-freeze to block scuppers.
Ulladh is offline
post #8 of 34 Old 08-25-2012
I used a tarp last winter and we had a few big wind storms. The tarp got shredded whilst the shrink wrapped boat near it (also more protected spot though) was fine.
I will still use a tarp again this year, but maybe a better one and try to tie it down tighter.
Sailing the Bay Of Quinte
S/V Dutch Treat is offline
post #9 of 34 Old 08-25-2012
Bring On The Wind
CatMan22's Avatar
I built a frame much the same as trusses on a house that I covered with 5/8" OSB then placed a tarpaulin over everything and secured it. Not only did it keep everything dry but the height of the peak allowed me access to to cockpit and cabin when I needed. One of my neighbors called it 'The Ark ' when I was building it. Plan on doing the same this winter.
CatMan22 is offline
post #10 of 34 Old 08-26-2012
asdf38's Avatar
It all depends on how well you do the tarp. I've done tarps two years and it's fine and a lot cheaper. I'll say I liked it last winter when I had the mast down. Then I had one 30' (32 or 24 would have been better for my 26) over a high wood frame. It was perfectly dry although I had a problem with a large storm disrupting the frame.
With the mast up the year before that I had 3 tarps. That was more difficult and less sealed off.
Use a combination of tying the tarp down and weights. I mostly used milk cartons and coke bottles although I definitely have a problem with them puncturing and leaking. Personally I like the idea of the weights because it seems a little like a release valve. If wind gets under the tarp they can lift up and spill it out.
The trick for anchoring lines to the tarp is to wrap the tarp around a golf ball and string a slipped knot around that. It's far more secure than the grommets and you can add them anywhere. Never tape the tarp with any load and expect it to hold. I watched the boat next to me try that and it was shredded shortly ("Oh we live nearby and will check it all the time" - didn't happen).
asdf38 is offline
Shrink wrap vs. Tarp labatt Gear & Maintenance 37 05-05-2011 07:19 PM
Tarp for storage: Light or Dark color? TakeFive General Discussion (sailing related) 19 11-28-2010 11:46 AM
ICW in Mid-Winter? mrybas Cruising & Liveaboard Forum 1 02-22-2010 11:02 PM
winter christinero Living Aboard 4 11-20-2004 12:52 PM
Aluminum gromets on tarp mikehoyt Gear & Maintenance 1 05-06-2002 09:03 AM
