08-31-2012
"Fairhaven" Formosa 41
Re: Sailboat without a mast
Originally Posted by pedalsteel
I'm new to this forum. Am planning to purchase a used 30' sailboat but I'm not interested in sailing. I would like to remove the mast except for about 8 feet for antenna mounting. Would like to do the great loop and not have to worry about a mast, also very economical cruising. Would removing the mast as described have any ill effects on the vessel?? Thanks Al.
I had to take the mast out of my wooden boat because of extensive rot/wood damage necessitating the removal of the keel as well.
Knothead is right. It will roll in an AWFUL motion that you will hate if you take the mast out. The hull shape of sailboats more resemble a canoe or kayak than a barge. Powerboats roll more slowly (read more comfortably) than sailboat hulls. The only thing that makes the motion of the sailboat roll comfortable is the weight of the mast far from the center of the roll.
Every seen ice skaters do spins? If they bring their arms close they spin quickly, if they spread them out they spin slowly. Same with your mast. If you remove that weight then all the weight in the boat is close to the center of the roll and every roll from every wave/wake will be head-snappingly fast. I've tried it both ways in the same boat. You will hate it.
On the other hand, if you leave the stick in place life will be more comfortable, you have the option of sailing if you choose, and your boat will retain resale value.
MedSailor
"True, your boat will outperform mine to windward, but my boat will always outperform yours at anchor." --MedSailor
