Sailboat without a mast - Page 7 - SailNet Community
 28Likes
post #61 of 85 Old 04-21-2013
Re: Sailboat without a mast
"Sawzall will work on rigging too"
If you want to bash stuff up that's a great idea. But sailboat rigging UNBOLTS so all you need to clear it, is a wrench. And the job is done cleanly.
Then you pull the mast, in one piece, and sell it. Again no Sawzall, unless your goal is just to bash stuff up and make a noisy mess.
hellosailor is offline
post #62 of 85 Old 04-21-2013
Large Member
GMFL's Avatar
Wasn't that the point of this whole thread??
GMFL is offline
post #63 of 85 Old 04-22-2013
krisscross's Avatar
If I was to remove the mast (remove, not destroy), I would install a fairly large water tank to balance the keel, somewhere on top of the cabin. You can always use more water. Keep the draft to 4 ft or less. If you are not in a hurry, it will be a fun trip. Wait for good weather to cross long stretches of open water or you will puke your guts out.
krisscross is offline
post #64 of 85 Old 08-16-2014
Originally Posted by BubbleheadMd View Post
No, it operates marginally in either setup. The Mac is the "spork" of boats. It does everything mediocre, and nothing very well.
Your definition of "perfect" is merely that it is capable of motoring and sailing at all. Yes, I've sailed aboard the Mac. I've also sailed rings around two of them in my Pearson 30. If you had any sailing experience, you'd know that although it sails, it doesn't sail all that well.
I'm not really sure what your point is here. You've made your decision, you're not looking for advice. You're looking for validation. Do whatever you like, but don't look at us for validation. Really, all you're seeking is a free beer-drinking platform on the water.
Your decision to turn a screwdriver into a hammer instead of just buying a hammer is your business. Good luck with that.
Just being an angry sailor? or an ass it seems to me!
The Mac meets his needs and allows him to later sail if he chooses to.
Wasn't that the real point of his needs?
Not stepping into this industry and be popeye from day one, but having a chance to get out on the water, do his thing, and then if he chooses to, begin sailing. He can achieve his goals with a Mac easier than with any other sailboat out there.
You must be stuck in your ways really deep. Sad to be your son I'd say.
Doc
DocParty is offline
post #65 of 85 Old 08-16-2014
Senior Citizen
Chas H's Avatar
Originally Posted by pedalsteel View Post
I'm new to this forum. Am planning to purchase a used 30' sailboat but I'm not interested in sailing. I would like to remove the mast except for about 8 feet for antenna mounting. Would like to do the great loop and not have to worry about a mast, also very economical cruising. Would removing the mast as described have any ill effects on the vessel?? Thanks Al.
Al-
Check out the ECO-Trawler (green hull) on D-Dock at the Manitowoc Marina. It may meet your needs better than a sailboat.
-CH
Chas H is offline
post #66 of 85 Old 08-16-2014
Boasun's Avatar
Just go under a low bridge, that will remove the mast.
Took 4.5 feet off the mast of the supply boat I was operating... Had a mate who (according to him), knew every thing about the area water ways around Morgan City La. He didn't.... went under the first two bridges without a problem That last bridge is what did me in...
Morale of the story!? Don't trust anyone who tells a good line about knowing it all.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Boasun is offline
post #67 of 85 Old 08-16-2014
Master Mariner
capta's Avatar
Nice part of the world, Morgan City, LA. I had a towing company from north Fla, send me there on a pointy bow tug drawing 10 feet and a barge around 300'. Only charts aboard were for the entry through the lock. No cables aboard, no winches fwd and no room in the lock to hip up.Came spinning outa the lock like a tether ball around the pole. And some folks think yachting is fun!
facebook.com/svskippingstone
Our Videos;
capta is online now
post #68 of 85 Old 08-16-2014
Over Hill Sailing Club
smurphny's Avatar
Originally Posted by k_p_m View Post
I too am curious what peoples burn rates really are. I know thats not the point of sailing, but some of you guys must keep track?
I average around 9.5 NM/gal. diesel. 35' full keel, Yanmar 3GM30F. 29 Hp. Hull speed is 6.4 knots. I usually run at 2600-2800 RPM.
smurphny is offline
post #69 of 85 Old 08-16-2014
Water Lover
Location: New Mexico, USA (Heron, Elephant Butte lakes); Arizona (Lake Pleasant)
The Macgregor bashers risk sounding a bit silly or uninformed if they assume ALL Macs sail the same. There was quite a lot of design variation throughout the Venture-Mac build history.
rgscpat is offline
post #70 of 85 Old 08-17-2014
TQA
Bombay Explorer 44
TQA's Avatar
First of all running around at sea with no mast is no problem ON THE GREAT LOOP! Sure when you get an ocean swell causing the boat to roll the roll will period will be less due to the loss of pendulum weight. How often will that be.
10 ft mast say an old windsurfer mast will do just fine and can be left unstayed and dropped easily if required.
A sailboat will be more economical than a trawler.
One thing I might do is add some pitch to the prop to get closer to cruising speed at max torque as fuel burn will be reduced.
Seems a reasonable idea and maybe the mast etc could be sold?
TQA is offline
Sailboat towed to shore after mast breaks - abc7news.com NewsReader News Feeds 0 08-11-2012 10:40 AM
Coast Guard tows sailboat back to shore after mast breaks - KTVU San Francisco NewsReader News Feeds 0 08-09-2012 10:10 PM
Stolen Sailboat Mast in Annapolis - ABC2 News NewsReader News Feeds 0 07-10-2007 06:15 AM
Sailboat mast scuffs underside of bridge - Myrtle Beach Sun News NewsReader News Feeds 0 05-27-2007 04:16 AM
mast for sailboat spainman General Discussion (sailing related) 0 11-28-2001 04:10 AM
