Mylar Spinnaker? - SailNet Community
post #1 of 7 Old 08-29-2012 Thread Starter
Mylar Spinnaker?
Hi. I just picked up a mylar spinnaker for my bucaneer 250. Its made by Ward sails. I never really heard of these except for americas cup. What little info i can find recomends them for light air. It looks cool. See thru with vetical seems. Does anyone have any experience with these, like what conditions to use it and stuff? Thanks
cousineddy is offline
post #2 of 7 Old 08-29-2012
Moderator
Jeff_H's Avatar
Re: Mylar Spinnaker?
In my experience they were a short lived fad for small higher performance boats. They permitted closer reaching angles in a wider wind range. They tended to be very fragile and need extremely careful handling, and a bit more skill to fly.
Jeff_H is offline
post #3 of 7 Old 08-29-2012 Thread Starter
Ok, so higher performace, lower durability. Which would be better in light air? I light nylon spinnaker? Or this saran wrap spinnaker?
post #4 of 7 Old 08-29-2012
SchockT's Avatar
I had a mylar chute for my last boat, but it was a very flat cut heavy air reacher.
Whether yours is good for light air or not depends on the cut and the weight of cloth used. For light air nylon has a bit more give than mylar or poly, so it tends to recover it's shape quicker when going through chop or stinkpot wake. On the downside, old nylon holds water and therefore gets heavy if it is raining or you go shrimping with it.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #5 of 7 Old 08-29-2012
tommays's Avatar
The weak point of any spinnaker is when you make a mistake and have and Explosive refilling which is pretty much how it sounds
So the firmer the material the less it can stand mistakes
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #6 of 7 Old 08-29-2012
Aspiring to be a Mexican
sww914's Avatar
Pretty crunchy for a spinny, isn't it?
sww914 is offline
post #7 of 7 Old 08-29-2012 Thread Starter
Yes, the material is stiffer than a standard chute. So, i think medium and heavy air reaching is when i will use it. It is light tho. Ill use the pretty color one for everything else.
Stinkpot....i gotta remember that. Thats funny. And shrimping, yum! Lol
Tags
buccaneer 250 , mylar spinnaker
cleaning mylar sails? Loualfr Gear & Maintenance 10 12-17-2013 02:03 PM
Mylar sail care? newshound Gear & Maintenance 7 05-20-2009 09:33 AM
repairing rip in mylar sail? purvisgs Gear & Maintenance 3 08-23-2008 10:36 AM
Mylar Genoa dvpamenter General Discussion (sailing related) 0 08-03-2008 10:05 PM
Mylar vs. Dacron Classic30 Racing 18 10-01-2007 08:07 PM
