Balboa 24 Project - SailNet Community
post #1 of 4 Old 08-30-2012 Thread Starter
acorn's Avatar
Balboa 24 Project
As I mentioned in my Intro, I just bought a Balboa 24. It's a bit of a project boat, but seems mostly solid. There is one soft spot starboard of the mast step, which I intend to try to fix from inside, since I do plan to re-do the interior/headliner. The only real issue I see is that someone has done some fiberglass work on the keel - particularly at the keel/hull joint on the port side. It looks kinda ugly, as they stopped work before sanding it down and smoothing everything out, but seems solid.
So here's my question - I have heard people say the first thing you should do with a project boat (that i got very cheap) is to put it in the water, and sail it as-is - i guess to make sure it's not gonna sink before you put much work in it, hehehe. Wait, that wasn't a question, was it?
So here's my question: Should I do this? I know I have bottom work to do, and the boat has to be out of the water for quite a while to do that... What do ya'll think?
Here's some pics of the boat:
Balboa 24 - a set on Flickr
With sails up:
Balboa 24 - hoist the sails! - a set on Flickr
--acorn
acorn is offline
post #2 of 4 Old 08-30-2012 Thread Starter
acorn's Avatar
Re: Balboa 24 Project
I should mention that I bought the boat on the trailer - and i'd say it has been on the trailer for months if not years.
acorn is offline
post #3 of 4 Old 08-30-2012
You don't want water in the layers of glass if it does leak. I would sand down any suspicious areas below the water line, and at least add gell coat, and a few layers of good bottom paint before the sink test.
I bought an Aquarius 23 last year, and after a few gallons of resin, and paint, and plywood, varnish,months of work, etc.....I now have a good solid working boat.
The Sun has Risen on a New Day filled with the Promise of Adventure.
CapnBilll is offline
post #4 of 4 Old 08-31-2012
Barquito
Barquito's Avatar
I would second sailing it a bit, once you make sure is looks seaworthy-ish. Unless you are an experienced sailor on that boat, it is hard to know what needs attention until you get it out there. Then that will give you ammo to work for months (or years).
Bristol 27
Cirque
For Sale
Valiant 32
Barquito is offline
Name my boat! Balboa 8.2 cd66312 General Discussion (sailing related) 26 07-12-2012 05:51 PM
Balboa 24, $700.00 mtboat Boat Review and Purchase Forum 2 07-01-2011 02:35 PM
balboa 20? SLObrett Boat Review and Purchase Forum 6 04-13-2009 07:49 PM
balboa 27 rskaug General Discussion (sailing related) 0 11-12-2002 09:25 AM
