Outboard installation - SailNet Community
post #1 of 2 Old 02-23-2004 Thread Starter
I have to take my motor off my 23 ft sailboat and I am not to worried about taking off, it is putting it back on. How do I do it and not drop it in the drink??
eric97217 is offline
post #2 of 2 Old 02-23-2004
A couple of suggestions. Cheapest and easiest way is to either bring the boat to the dock or bring a dingy up to the stern of the boat and lift it off. You can also buy a lift handle like easy lift from c-level or engine caddy from davis. Both give you a lifting handle on top of the engine. if you want to get really clever, you can disconnect your main sheet and use the boom to hoist the engine off. I would strongly suggest you get a friend to help out as well
hamiam is offline
Outboard motor controls waltzingmatilda Gear & Maintenance 3 05-05-2010 09:08 AM
Outboard: Buying, Type & Fitting omega001 Gear & Maintenance 11 11-10-2006 10:09 AM
outboard zincs SteveHill Gear & Maintenance 1 01-01-2004 10:32 AM
Autohelm 6000 Installation saildutch Gear & Maintenance 3 06-07-2001 05:05 PM
Outboard Motor Shaft Length hilly50 Gear & Maintenance 2 05-14-2001 03:50 AM
