Cross Florida Canal - SailNet Community
post #1 of 7 Old 09-03-2012 Thread Starter
Cross Florida Canal
We are planning a trip to Florida this winter (Tartan 37) and one option is to go around the keys and up the Gulf side. On the return trip, we are considering the Cross Florida Canal to avoid the long trip back around the Keys.
Has anyone taken this recently? My concerns: water depth, (we draw 5 feet); bridge clearance (we have 55 feet); and powerlines and other obstructions.
Also, how much time did it save?
We would appreciate any information. Thank you.
Al & Diane Dashevsky
s/v Always Sumthing
dashman is offline
post #2 of 7 Old 09-03-2012
priscilla's Avatar
Re: Cross Florida Canal
I took a 60' sports fisherman across this June that drew 5' and had no problems. BILL
Priscilla
priscilla is offline
post #3 of 7 Old 09-03-2012
FSMike's Avatar
The "Cross Florida Canal" aka Cross Florida Barge Canal never got completed.
You can transit across Florida via the Okeechobee waterway but the max air draft is 49' I believe. There was a fellow near that bridge who could heel your vessel over using water ballast but I'm not sure how much he could lower your rig.
The US Corps of Engineers will have current info about depth, lock closures, etc.
You can Google search all kinds of info on the route.
Sail Fast Live Slow
36' Solaris Sunstar catamaran
FSMike is offline
post #4 of 7 Old 09-03-2012
ebs001's Avatar
As I recall the maximum air draft for barreling is 56 feet.
ebs001 is offline
post #5 of 7 Old 09-03-2012
Info on the Okeechobee Waterway:
Okeechobee Waterway Guide - Navigation, Bridges, Locks, & Water Levels
Not sure if you can make it... there was a guy at the rail bridge that restricts mast height clearance that would help you get under by heeling the boat over. I'm not sure if he is still there or what mast height limits he might need to impose to do this safely.
sd1953 is offline
post #6 of 7 Old 09-03-2012
Old as Dirt!
svHyLyte's Avatar
The folks at Indiantown Marina (772-597-2455) might be able to help you get in touch with the Barrel Man. He was working out of there when we went through with our old boat although its been quite a while since then. The one thing I can tell you about that trip was it was boring as heck--save in the Locks--and very buggy (mid-October). Also, be sure to check bridge clearances in Ft. Myers as you might have difficulty there as well. I seem to recall one lower bridge.
FWIW...
svHyLyte is offline
post #7 of 7 Old 09-04-2012
denverd0n's Avatar
So, to summarize...
1) It is called the Okeechobee Waterway. Search on that for information, not on Cross Florida Canal.
2) 5 feet of draft is usually not a problem, and with all the rain this year is definitely not right now, but check with the Army Corps of Engineers for most current details...
U.S. Army Corps of Engineers®*— Jacksonville District
3) 55 feet of airdraft is an issue. You will have to heel it over almost 30 degrees from vertical in order to clear.
Personally, if I had a boat with 55 feet of airdraft (does that include things like antenna, wind indicator, etc?) I would schedule for a time when I could take a leisurely trip through the Keys and enjoy the journey.
denverd0n is offline
Southern Cross 31? db27513 Boat Review and Purchase Forum 36 09-02-2016 12:48 AM
Waiting to cross Vasco Cruising & Liveaboard Forum 15 02-03-2010 08:34 AM
Looking to cross Atlantic Profoundjester Crew Wanted/Available 0 10-26-2008 04:19 PM
I´m looking to cross the Atlantic Nanfer Cruising & Liveaboard Forum 17 03-27-2008 10:04 AM
southern cross anneminix Boat Review and Purchase Forum 3 12-03-2006 01:42 AM
