2QM15 Fuel System Need Help - SailNet Community
 3Likes
  • 1 Post By jsaronson
  • 2 Post By jppp
post #1 of 8 Old 09-07-2012 Thread Starter
I just bought a San Juan 28 knowing the engine hadn't ran in about 2 years. I have pumped out the old fuel, changed the filters (that were plugged), had the injector pump checked out, bench tested and radared and still can get this thing to run. Now I am questioning the mechanical pump and the volume of fuel that it is supplying to the injector pump. I have been looking online for a new mechanical pump but... I need help, Suggestions? Questions? Fire away... thanks
Lanky55 is offline
post #2 of 8 Old 09-07-2012
jsaronson's Avatar
Re: 2QM15 Fuel System Need Help
You need to start at the tank and work forward and up.
Is the pick-up in the tank clean? Fuel line clear? Have you bled the system? Is the filter full of clean fuel?
Is fuel getting to the injectors?
That engine can run for hours on a gallon of fuel so I would not expect the pump to have much output.
HDChopper likes this.
jsaronson is offline
post #3 of 8 Old 09-07-2012
jppp's Avatar
Been through this. Need more info. If fuel is getting to injectors it should run. When I thought I had bled the system, I hadn't.
First question is, Is there fuel at the injectors? Do not confuse the return line banjo with the injectors. Injectors are on the side. Crack open the nut on the injector and turn over. Start with the front injector and then do the rear. Don't stop at the front one.
HDChopper and flyingjib like this.
1985 C&C 35 MK 3
jppp is offline
post #4 of 8 Old 09-07-2012
you can replace the machanical pump with a low pressue 12 volt electrical one from any auto parts about $30 bucks,yanmars are notorius for being hard to bleed,you can use a small amount of ether [not much]sometimes that will work
sawingknots is offline
post #5 of 8 Old 09-07-2012
fryewe's Avatar
Put a squeeze bulb between the fuel supply and your diaphragm (feed) pump and prime using it until you get fuel without bubbles at the filter then at the injectors. You can pick one up at Walmart for a few bucks. Check your fuel lines to see if you need a bulb with quarter inch or five sixteenths fittings. Squeeze the bulb while venting then tighten the banjo before allowing the bulb to refill. Repeat until no air.
fryewe is offline
post #6 of 8 Old 09-08-2012
1979 C&C 30 MK1
flyingjib's Avatar
I had to bleed mine recently after changing the fuel filters and it took a while to get it going. Jppp is spot on. Here is the manual's instructions:
http://i.imgur.com/oywoO.jpg
http://i.imgur.com/FcEYg.jpg
flyingjib is offline
post #7 of 8 Old 09-09-2012 Thread Starter
I am not getting fuel to the injectors. I do have fuel to the injector pump but not a very large quantity when I turn the engine over. It pulsates a small quantity not a solid stream. I had the injector pump bench tested by a shop and put under the radar. they said that the injector pump appears to fine. But I do not get anything on the high side. I am considering installing an electric pump between my large coleser filter and the mechanical lift pump. also considering by-passing the lift pump completely and going to the secondary filter just prior to the injector pump. suggestions??? BTW Thank you in advance for your participation.
Lanky55 is offline
post #8 of 8 Old 09-10-2012
Freedom 39
FarCry's Avatar
You won't see much fuel at all at the injectors, injector pump etc. Did you crack open the fitting on the high side of the injector pump and are not getting fuel there?
You do know that the 2QM15 does NOT have a separate fuel kill system, right? The fuel cut-off is integral with the throttle. Have you tried to advance the throttle, open the decompression levers and have someone crank the engine to pump fuel?
If the throttle is all the way back, it will effectively stop fuel flow through the high pressure pump.
FarCry is offline
2QM15 Fuel System Need Help Lanky55 Gear & Maintenance 0 09-07-2012 12:20 PM
yanmar 2qm15 fuel problem pfirth Diesel 11 05-11-2011 12:23 PM
Yanmar 2qm15 fuel problem pfirth Diesel 10 04-09-2011 01:20 AM
yanmar 2qm15 fuel problems pfirth Diesel 6 04-01-2011 01:40 PM
Yanmar 2QM15 Bleeding Fuel System - HELP shipley Gear & Maintenance 5 03-11-2002 07:21 PM
